1 - 20 of 32 Posts
Been looking around for a extended warranty plan, and found one called autopom. they quoted me for a 3yr and 45,000 miles(starting after purchase) 4 options to choose one. was looking into the standard coverage which is 1,390.00 It covers
Engine – (including diesels): All internally lubricated parts contained within the engine including: pistons; piston
rings; connecting rod bearings; crankshaft; crankshaft main bearings; camshaft; camshaft bearings; cam
followers; timing chain or belt; timing gears; guides; tensioners; rocker arms; rocker shafts; rocker bushings;
cylinder head valves; valve covers; valve guides; valve lifters; valve springs; valve seals; valve retainers; valve
seats; push rods; water pump; oil pump and oil pump housing; harmonic balancer; oil pan; timing chain cover;
intake and exhaust manifold; valve covers; engine mounts; seals and gaskets, Rotary Engine Coverage: rotor
chamber and all internal parts. Engine block and cylinder head(s) are only covered if damaged as the result of
the failure of an internally lubricated part
2. Turbocharger/Supercharger (factory installed only) –All internal lubricated parts including seals and gaskets.
Turbocharger/Supercharger housings are only covered if damaged as the result of the failure of an internally
lubricated part.
3. Transmission – (Automatic or Standard): All internal parts including: torque converter; flywheel/flex plate;
vacuum modulator; electronic shift control unit and solenoids; transmission cooler; transmission mounts; oil pan;
seals and gaskets. Transmission Case is only covered if damaged as the result of the failure of an internally
lubricated part. Coverage is not afforded for standard transmission clutch assemblies, or any of their component
parts.
4. Transfer Case – All internal parts including seals and gaskets Transfer Case is only covered if damaged as the
result of the failure of an internally lubricated part 5. Drive Axle – (Front and Rear): Drive axle case; all
internal parts contained within the drive axle; locking hubs; drive shafts; center support bearings; universal
joints; constant velocity joints (unless they are damaged by the failure of a leaking CV book or lack of lube); axle
bearings; four-wheel drive actuator; differential cover; seals and gaskets.
5. Drive Axle – (Front and Rear): Drive axle case; all internal parts contained within the drive axle; locking hubs;
drive shafts; center support bearings; universal joints; constant velocity joints (unless they are damaged by the
failure of a leaking CV book or lack of lube); axle bearings; four-wheel drive actuator; differential cover; seals
and gaskets.
6. Steering – All internal parts contained within the steering box; rack and pinion gear; power steering pump; power
steering hoses; steering knuckles; pitman arm; idler arm; tie rod and tie rod ends and drag link; steering
dampner; upper and lower steering column shafts and couplings; including tilt-wheel mechanism; steering box
and rack and pinion gear housings; seals and gaskets. Real Wheel Steering: rear steering shaft and couplings;
power cylinder and pump; electronic control unit/solenoid; phase control unit; stepper motor; Steering-Box;
control valve; rack tie; rod ends; seals and gaskets.
7. Brakes: master cylinder; power brake cylinder; vacuum assist booster; hydro boost; disc brake caliper; wheel
cylinders; compensating valve; brake hydraulic lines and fittings; hydraulic control unit; seals and gaskets. The
following ABS parts are also covered: electronic control module; wheel speed sensors; hydraulic pump/motor
assembly; pressure modulator valve/isolation dump valve; ABS relays; accumulator; seals and gaskets.
8. Electrical – alternator; voltage regulator; starter motor; starter solenoid and starter drive; main engine
compartment wiring harness; ECM/PCM; electronic ignition module; crank angle sensor; knock sensor; ignition
switch; ignition switch lock cylinder; front and rear window wiper motor and P.C. board; washer pump and
switch; stop lamp switch; headlamp switch; turn signal switch; heater/AC blower speed switch; manual
heater/AC control head; horns; power door motor.
9. Air Conditioner – condenser; compressor; compressor clutch coil and pulley; air conditioning lines and hoses;
evaporator; idler pulley and idler pulley bearing; high/low compressor cut-off switch; expansion valve; pressure
cycling switch; seals and gaskets. The following are also covered if damaged by a covered part listed above:
accumulator/receiver dryer; orifice tube; oil and refrigerant; seals and gaskets.
10. Front and Rear Suspension - upper and lower control arms; control arm shafts and bearings or bushings; upper
and lower ball joints; radius arms and bushings; torsion bars and mounts or bushings; stabilizer bars; links and
bushings; struts (excluding cartridge inserts); strut bearing mount/plates; spindle and spindle support; hub or
wheel bearings; seals and gaskets. Variable Dampening Suspension: compressor; control module; air bags;
actuator; solenoid; height sensor; mode selector switch; seals and gaskets.
i have a 2013 challenger RT with 48,000 miles they wont cover me. Autopom is registered with California Department of Insurance.
Stick with the Chrysler extended warranties. Numerous others come and go, and can leave you with nothing but a piece of paper.
Agree 1000% !! Back in 2001 I bought a new Chevy Monte Carlo SS Pace Car edition. I told the salesman I wanted the best warranty GM offered. I paid $2000 for it and went on my way. Very stupidly I didn't look at the papers to see it was a third party warranty. Guess what, 3 years later they are out of business and I have no warranty. That was and will be my last GM vehicle. What's the old saying? Screw me once.... Previously I was a Chevy guy and had bought a bunch of them over the years....
Best advice I can offer is check with the techs where you will have your car worked on and which will probably be involved with any warranty claims made to see what experience they have had with this extended warranty coverage company.
Even the best companies put up a bit of a fight to avoid paying a claim, seeking any reason to deny the claim.
Be sure you also read what you have to do to keep the coverage in effect. What service schedule, inspection schedule, mileage or usage limitations there might be.
Ok just recieved a call from Chrysler factory warranty and to get the mopar protection plan I have to take my car to get inspected at a FCA dealership.
Done Deal, Just purchased a MVP extended used car warranty (powertrain) 3 yr and 36,000 miles. Cant be to sure on the Hemi tick issues that I been hearing about, better be safe then sorry
A Hemi tick issue may not be covered. Just a noise with no other untoward engine behavior, no CEL, the determination could be there is no problem, that the noise is "normal".
Discussion Starter #13
I know is normal, Ive seen bad lifter eat away camsshafts. and I have a feel my exhaust manifold is giving out soon sounds a bit weird.
I thought I read here recently that FCA was going to stop with the Lifetime warranties. Is that still the case?
Discussion Starter #15
I think your correct. While looking for MVP plans I didnt see any unlimited plain. only unlimited miles but with a set years.
Yes, no more Lifetime warranties
Discussion Starter #20
I dont know of any pre-existing problem that my vehicle has. remember a ticking noise is not a existing problem.
1 - 20 of 32 Posts
