Only if the caps for your valve stems are flourescent green
The only down side is MOISTURE created by the compressor. So you need a water seperator on your compressor.My compressor at home fills my tires with abut 78% nitrogen. That's all the nitrogen my tires (or anybody's tires on a street car) will need.
Yeah, but that extra 21% makes a WORLD of difference! LOLOBTW - The air that we breath and put in our tires is about 79% nitrogen.
My Mopar 10 came with a Plastic bag and card in the glove box with a web address where I registered. It mentioned Nitrogen and I had no idea what it meant. My wheels do have the fluorscent green caps.
Question: Can I fill them with air if they are low on pressure? If not, where can one get Nitrogen to fill the tires. Thanks for your help guys..:scratchhead:
Care to quote your source on that statement?Yeah, you can use plain air. The whole nitrogen thing is a gimmick at best.
Tom
Tom
Can aluminum corrode?And if they are, remove them right away and put basic plastic ones on.
The aluminum caps will corrode and will cost you a TPS sensor when you try to remove them.
Tom
I don't question what you're saying at all. All I'm saying is that I've had no problems with the alloy caps I've run for the last 9 months.There's plenty of threads on broken stems on LXForums. I personally lost 2 TPS sensors on my Magnum (daily driver) cause we couldn't get the caps off and the stem snapped off with a moderate amount of pressure.
Hydrogen is for geeks & trolls....i fill mine with helium!Pfft. Nitrogen is for wimps. I fill mine with Hydrogen![]()
