Although this has been discussed a number of times in different threads I have decided to post my install.
You can order the kit directly from Web Electric or a board supporting vendor.
Normally it takes an 1 to 2 hours depending on your skills.
Tools
Normal hand tools, a panel tool and a #20 Torx bit.
What's in the box?
Everything you need to do the install including tie wraps and a Lifesaver mint.
How To
Following the instructions you start by removing the right and left taillights.
To do this you take off the cover panel with panel tool.
Next remove the panel covering the back of the trunk. This makes it easier to finish removing the taillights and you will need this space open later to install the phone cord and connecting cord from the taillights in the trunk lid. Use the panel tool to remove the 5 scrivets that hold the panel on.
Next remove the plastic nut that holds the taillight panel cover on. Now pull the panel back and you will see another plastic nut and the connection to the taillight.
Remove the connector by releasing the orange retainer, just hook your finger nail on the edge and push/pull. Now press on the back part of the connector and pull it off the taillight. Remove the plastic nut and you can remove the taillight.
Now repeat for the other side. Once you have the taillights out, follow the instructions to add in the new socket and tape up the unused one.
Now reinstall the taillights.... Following the instructions you will install the sequencers and phone cord.
Note - if you leave the phone cord disconnected at one end the brake lights and hazards will sequence. This may be ILLEGAL in some locations.
Do to limitations on the total images that can be posted I will finish this install in parts. Part 2 the trunk lid lights to follow.
Tools
What's in the box?
How To
