1 - 20 of 38 Posts
Now its time to tackle the trunk lid lights. You need to remove the cover at each end of the taillight assembly. Be careful as the clips that hold it on can break.
Next remove the torx screw just inside the end of the taillights.
Now remove the 4 plastic retaining nuts and 2 scrivets.
Now comes the hard part if you are doing this alone like I did. Use the heal of you hand and lightly hit the ends of the taillights to pop the assembly loose. Once loose you need to disconnect the wiring connector.
Now take the assembly over to the work bench and install the new harness per the instructions. Be sure to use the retaining clips to hold the wires in place so nothing gets pinched during re-assembly.
Now re-install the taillight assembly in the trunk lid. Here is where a 2nd pair of hands would be nice as you need to install the NEW connecting wires and grommet plus connect the original wiring harness.
Now is the time to check the alignment of your taillights before you tighten down any of the retaining nuts.
Next you need to the install the connecting wire from the trunk lid to the sequencers. I elected to completely remove the trunk panel. Use the panel tool to remove the scrivets.
I decided I wanted to run the wire in the factory loom. So, I cut the tie wraps off and threaded the wire in the loom down to the trunk. I added a tie wrap to loom where the new wires exit the loom to keep the wires from coming out. I then re-install the tie wraps I cut off the factory loom and wal la it looks just like it did before.
I threaded the new wiring harness behind the trunk cover. I took out the scrivet holds the panel in and routed the wire below the hole where the scrivet is placed. This will prevent the wire from coming out from behind the panel. Now is the time to untangle the new wire harness before you install it. Once installed you should be done. Check to make sure all you connections are done before you test the system. Once you test the system you can tie wrap any of the wires to the factory harness to make a nice clean install.
If everything checks out re-install all your panels and tighten the retaining nuts - YOUR DONE!
Sequential Turn Signal Kit
Hi and thanks for the great instructions and pictures. I am planning on having my shop install the Web Electric sequential turn signal kit and the Mopar shifter next week. and I have printed your instructions for them.
The sequential kit looks a little scary, so should I be concerned at all? This shop works on corvettes, camaros, etc and while they seem very professional these Challenger installs will be new for them.
Just looking for your perspective, as someone who actually did the installs.
Thanks!
Actually the kit is a piece of cake so to speak. 2 people could do it less than an hour if then have done one before. In reality your only replacing 1 set of light connectors and the rest is add-on wiring. No factory wires are cut and everything just snaps together.
To me this is no more than a 1 hour labor charge.
PS - I use to go to Boca when I worked at IBM in Austin, TX.
Install is a breeze...... less than an hr no problem... just a note.... if you do not install the telephone cord, your brake lights will also sequence once when you initially apply the brakes, however this is illegal in some states. I Love my Webelectrics
If were to do it again.... I would remove all the panels and taillights before you install any wiring. Much quicker.
Install the phone cord but just don't hook up one end. That way if you get stopped or questioned all you need to do is remove the panel and plug it in.
Getting Sequential Installed on Monday
Thanks for all the good information. I spoke to my shop (Horsepower Sales in Pompano Beach FL), and they are very familiar with the sequential turn signal installs, and to them its easy. That makes me feel better!
I am also getting them to install the Web Electric 3rd brake light pulser, and some other goodies, but the big item is the Corsa Xtreme cat back exhaust.
While I did not say earlier, my Toxic Orange 6 speed 2011 SRT-8 just arrived at the dealership and I am having them ship the car on a flatbed tow truck on Monday to HP Sales. If all goes well I will get it Tuesday AM, and drive right to Tint World for window tinting. Then on Thursday I have an appointment for the Nav TV backup camera system.
I also have stainless trim items to install, which I plan to do after all these items.
As you can imagine I am TOTALLY STOKED about the new SRT-8!!!!!!!!:)
I was wondering about pulsing with brake lights/flashers.ill try removing phone cord.i love the way they look.great product.
Just did mine today. Install was a breeze, took me about an hour to complete. Taking everything apart first worked really well, thanks for that tip. I think they flash a bit quick as my brother in law has them on a Mustang and they are slower, but what the hey, I love them!
So Hemi57; you're from Jarrell? I used to hang out there when I was in High School. (Don't ask when that was, please). I'm in Taylor.
Reactions: Chasboy
Yep... I have a shop in Coupland so I go thru Taylor a lot.
Discussion Starter #13 (Edited)
I have thought about that and it could be a problem do to the lower power requirements of the led's.
I sent an email to Web Electric and ask the question knowing that the flashers are computer controlled, no mechanical flasher, and here is his answer
You are correct. You cannot change the flasher (computer) so you must add loads. You can get loads wherever you buy the LED replacement bulbs, however, they get HOT. Mounting will be a consideration.
You will need 2 loads on each side, connected to the turn signal wire.
Thanks for the pics. I've been wanting these and this information is a great help.
2010 Dodge Challenger R/T Classic
In case anyone can't read the crappy photocopy that comes with the kit you can print out the entire assembly in pics and written instructions right off the Webelectrics site. Takes 9 pages or so. Good quality colour pics. That's what I did. :bigthumb:
I've got a set of brand new ones for sale - still in box. If interested, PM me
Anyone interested? Bought em and decided not to put em on after all.
Thanks again surfnlawguy!! I love them. i installed them today and i only took me a hour to do. Really easy to install
Great! They def add something to the cars.
1 - 20 of 38 Posts
