Noticed that too, no idea what it is though
yep,its the blend door opening or closing, ive watched the small white arm moving under dash...not sure if its normal? but mine does it too...sounds like the HVAC doors calibrating themselves
How long have you had your car? It's normal if you have been running the air conditioning. If I'm inside my car for more than a few minutes after shutting it off, it sounds like it's haunted.It doesn't seem normal and never did that before I think it is a bad relay
ignore it, 1 post after a 9 year old post...How long have you had your car? It's normal if you have been running the air conditioning. If I'm inside my car for more than a few minutes after shutting it off, it sounds like it's haunted.![]()
Just a heads-up...avoid responding to very old posts and as for relays...they are in the fuse boxes (there is one under the hood and one in the trunk)....not under the dash.It doesn't seem normal and never did that before I think it is a bad relay
