1 - 16 of 16 Posts
hello im planning to modify my car with some bolt ons
slp loud mouth 1
kooks long tube headers 1 7/8
custom made mid pipe off road
ported throttle body 87mm
slp pulley balancer underdrive 25%
speedlogix cold air intake
thermostat jet 180
catch can
diablosport tuner "ill contact johan to tune it via email's"
so what do u think? do i need to replace some of these parts? or shall i add something with it?
how much hp i would gain?
ty:silly:
I have some of those mods I love all of them
http://www.dragtimes
slp loud mouth 1
thermostat jet 180
catch can
ty:silly:
Assuming you have a 392, I would save your money on the TB... Your stocker can get you into the 11s N/A'd. Your tune will give you more throttle boost (response) and that is what 90% of the TB does as the stocker flows well enough until you go FI’d.
Personally I think the factory shorties flow very well too so the LTs would be a back burner item for me. Going catless with the stock shorties will make it plenty loud. Catless may get you .05 seconds and 1 MPH in the 1/4 but it will smell awful. The SRT Cats really flow good.
Just my 2 cents…
Reactions: teddyp
‘13 Challenger SRT 6M
If your going CAI the '11 and up 392s are great. That being said, if your looking for performance I'd go with one of those "true" type that pull in the air from the fender well area, not the heat soaked engine bay.
Sent from AutoGuide.com App
slp loud mouth 1
thermostat jet 180
catch can
ty:silly:
... also if your doing the 87mm get the intake manifold ported also. I did. I have a separate post a about it. I DO NOT have pre/post dyno numbers-however running the car for the first 5500 miles with out the two ported, I can absolutely tell something changed, and it's no placebo effect. PEAKSPEED. They are a vendor here. Dudes name is Bob. Super nice guy. Tell him you read about his business from some of us forum members. Keep us posted.
Discussion Starter · #8 ·
thnx man
can u do me favor and send me the exact link for the 6.4 hemi...ty!
thnx guys :)
about the true cai ...bro my car a daily use car..that true cai would suck water -.0
If it did then you would hear about it on these forums. I have been using one on my daily driver for probably a year now with no issues.
well one of my friend he has camaro 2002..his engine sucked water cuz of the true cold air intake
Different car, different intake. Doesnt apply here.
You would have to completely submerge the filter in water for it to suck it up. Why would you drive your car in water up to the headlights?
I have a true CAI fender type. You would literally have to drive the car into a puddle or small body of water approximately 18" deep to start sucking up water. My car car has seen drizzle, only because the weather wasn't forecast accurately. I have no worries.
If you're going longtubes with catless midpipes to SLP 1, then it is gonna be VERY loud and quite raspy. I personally think the regular CAI look a lot better than the true CAI fender type. I've also read you don't see very much gain from the SLP underdrive pulley unless you're FI.
Wrong. You don't put an under drive on a FI motor. If anything you want an overdrive pulley for more PSI.
^^^^ must've read a thread about it wrong then. My mistake!
1 - 16 of 16 Posts
