Because Tremec themselves has stated using anything else WILL cause damage to the transmission. Dunno about the rest of you but I'm gonna take their word for it.
I always go with manufacture spec and avoid the snake oil. If amsoil and RP made such a big difference the auto manufactures would use it. They are just taking your money.
this is why a tremec is a tremec and tremec will support its client (Ford, Chrysler, GM, etc...) in routing us, consumers, to the respective OEM branded products so everyone wins;
margins on cars are not that substantial, related branded products allow an OEM to make its money, this is why the recommendation is so strong and warranties can sometime be tied to the use of the OEM product in question
use whatever u think works, if you don't know, go OEM
I changed mine at 500 miles to RP with synchromesh and glad I did the trans was a qt low from the factory could not believe it. the trans shifts much better now and seems quieter also
I called Tremec because Ford, GM and Dodge all used the TR6060 but each specs their own fluid.
Tremec recommended Mobil 1 Synthetic ATF, but also stated that the manufacturer warrantees the tranny, so....
If you want to stay within warranty, then use the Manufacturer's Fluid.
I went with Mobil 1 based on Tremec's recommendation; I did not notice much, if any difference.
I have 8000 miles on my RT and I have changed the transmission fluid 4 times. LOL
I was trying to get rid of the nibble shifting from 2 to 3 gear.
I changed the OEM fluid and went with amsoil multi-vehicle ATF at 1,250 miles. The shifting got a little better but I wasn't satisfied. I change it again at 4,200 miles and went with Redline D-4 ATF. I felt no difference in the shifts and decided to change it again at 5,500 miles. This time I went with amsoil synchromesh manual transmission fluid. It made no obvious difference, so I changed it again at 5,650 miles and went back with amsoil multi-vehicle ATF.
I now have 8000 miles on the car and the transmission is shifting smoother. A lot of people say that the transmission just needs some miles on it before the shifts get smoother. Maybe that was the case with mine.
I do realize that amsoil is not what tremec or Mopar recommends for the transmission, but I'm staying with it.
I went with Redline C+ATF a couple thousand miles or so ago (Maybe 4k miles now) and, honestly, I don't notice any difference compared to the Mopar ATF+4 synthetic. 1-2 will still grind when cold if I'm not careful and 2-3 is notchy also when cold.
Once all warmed up it shifts just fine in all gears.
are you talking about a manual or auto trans. never heard of manual trans fluid with a bad smell. I used redline in my 2000 vette and there was a noticeable difference not sure of the tranny in there but I think it was a zf. but it called for auto fluid as well. . right now im leaning toward a redline trans fluid change
Yeah, most of today's modern manuals take ATF fluids although there is a few that still take straight gear oil...the worst a manual would smell would be 90W gear lube...I think the bad Oder from diffs come from additives either added or already in the factory oils in that when they break down from years of heating and cooling cycles they'll just knock you over when drained they reek so bad LOL
I changed my Camaro's TR6060 ATF with Royal Purple - THAT STUFF STANK!
I made the BIG MISTAKE of washing the towels that I used to wipe up some that had spilled. My washer still smelled even after several loads.
Mrs. RiChallenger was not a happy racer.
Ok, here we go, I found the fill plug (nice location) is the drain plug under the tranny brace ? it's cool I can remove this stuff, I can fill it with a syringe, It's not the first car I've had to bend over backwards, I'm just older thats all.
Thanks
KB
Thanks
KB
Damn it, I'm really in need of this. I'm leaning towards the AMSoil ATF. FWIW, I typically avoid 2nd gear until about 10-15 minutes after I started driving. I'm anal about letting the car warm up. I start it every day and let it idle for 5 minutes or so to let warm fluid circulate. Also, I wait until the idle drops from High Idle down to 750 rpms. Other than that, nothing different.
