So ive heard from not to get "cheap" gas because it has more water in it or its a lesser quality of fuel. Is there any validity to this? I typically have gotten gas at shell or other main stream fueling stations.
Thoughts?
Thoughts?
If you typically go to Shell continue to do so.So ive heard from not to get "cheap" gas because it has more water in it or its a lesser quality of fuel. Is there any validity to this? I typically have gotten gas at shell or other main stream fueling stations.
Thoughts?
No water in gas otherwise all of our cars would be dead. It’s additives that sets them apart. For example Wawa gas is cheap because they don’t have all the lovely additives that help keep your engine running clean. That’s where you hear people say to stick to top tier gas like BP, Shell, Mobil1 etc. Also helps negate the extra step of an ejection cleaner.So ive heard from not to get "cheap" gas because it has more water in it or its a lesser quality of fuel. Is there any validity to this? I typically have gotten gas at shell or other main stream fueling stations.
Thoughts?
I can get bp and shell for less than wawa lately, something’s backwards there lately.No water in gas otherwise all of our cars would be dead. It’s additives that sets them apart. For example Wawa gas is cheap because they don’t have all the lovely additives that help keep your engine running clean. That’s where you hear people say to stick to top tier gas like BP, Shell, Mobil1 etc. Also helps negate the extra step of an ejection cleaner.
As long as it’s the same top tier you won’t hear a complaint from me. 😂I can get bp and shell for less than wawa lately, something’s backwards there lately.
5.7 should get 89 octane, the regular is best saved for rentals.Yeah, I never thought it was a wise choice to the dusty, old, local boy gas. Sticking with the main companies (or top tier as previously mentioned). I recently got a Sam's club membership. I would think Sam's club gas and Walmart gas is the same? Ive maybe used Walmart gas once or twice since Ive gotten my challenger but mostly Shell or Chevron, sometimes racetrack but where I am at, they are most expensive for some reason... Also if it matters I am running regular 85. nothing special
Owner manual says otherwise... are you saying dodge is wrong?5.7 should get 89 octane, the regular is best saved for rentals.
You can get away with 87 if you have an auto, the computer will adjust the timing, If you have a manual it's 89 only.Owner manual says otherwise... are you saying dodge is wrong?
Asking not being sarcastic
