1 - 16 of 16 Posts
Some say you can't teach an old dog new tricks. But the innovative continuously variable transmission (CVT), which Leonardo da Vinci conceptualized more than 500 years ago is now replacing planetary automatic transmissions in some automobiles. Since the first Toroidal CVT patent was filed in 1886, the technology has been refined and improved. Today, several car manufacturers, including General Motors, Audi, Honda, Hyundai and Nissan, are designing their drivetrains around CVTs.
Cars with CVTs, sometimes called shiftless transmissions, have been common in Europe for years. But it's taken a while for the technology to gain a foothold in the U.S.. The first production automobile to offer a CVT in the United States was the Subaru Justy in 1989. This was followed by the Saturn Vue in 2002 and Ford in 2004.
How Does a CVT (Continuously Variable Transmission)Work?
Instead of a normal transmission that has gears that are different sizes to produce different ratios, a CVT essentially has an unlimited number of ratios. The most common type of CVT operates on an ingenious pulley system that allows an infinite variability between highest and lowest gears with no discrete steps or shifts. It contains two 20 degree cone-shaped objects with a V-belt wrapped around them.
One input cone brings in power from the engine and one output cone takes power out of the transmission and to the drive axle(s). The belt travels around both cones and is actually what transmits power from the engine to the wheels. The cones slide back and forth so that the belt is traveling in low gear on the larger part of the engine side cone and the smaller part of the axle side cone, and then in high gear, smaller part on engine side, larger part of axle side. The different diameters of the different parts of the cones are what provide the different ratios. However, the movement of the cones is so seamless, that the rpms remain constant to keep the engine in its power band so that you get the best performance possible.
1014935
A belt-driven design offers approximately 88% efficiency, which, while lower than that of a manual transmission, can be offset by lower production cost and by enabling the engine to run at its most efficient speed for a range of output speeds. When power is more important than economy, the ratio of the CVT can be changed to allow the engine to turn at the RPM at which it produces greatest power. This is typically higher than the RPM that achieves peak efficiency. In low-mass low-torque applications (such as motor scooters) a belt-driven CVT also offers ease of use and mechanical simplicity.
CVTs should be distinguished from power-sharing transmissions (PSTs), as used in newer hybrid cars, such as the Toyota Prius, Highlander and Camry, the Nissan Altima and newer-model Ford Escape Hybrid SUVs. CVT technology uses only one input from a prime mover and delivers variable output speeds and torque, whereas PST technology uses two prime mover inputs and varies the ratio of their contributions to output speed and power. These transmissions are fundamentally different.
1014937
Automakers are using CVTs for several reasons. A CVT can get maximum power out of a small engine for quicker and more responsive acceleration. That’s why you’ll most often find CVTs used in vehicles having four-cylinder engines. Hyundai, for example, is offering its version of a CVT, called an Intelligent Variable Transmission (IVT) with its 2.0L engines for the 2020 models.
The introduction of new materials makes CVTs even more reliable and efficient. One of the most important advances has been the design and development of metal belts to connect the pulleys. These flexible belts are composed of several (typically nine or 12) thin bands of steel that hold together high-strength, bow-tie-shaped pieces of metal. Metal belts don't slip and are highly durable, enabling CVTs to handle more engine torque. They are also quieter than rubber-belt-driven CVTs.
1014938
Other Versions of CVTs
The Toroidal CVT system replaces the belts and pulleys with discs and power rollers. Although such a system seems drastically different, all of the components are analogous to a belt-and-pulley system and lead to the same results- a continuously variable transmission.
1014939
A second type of CVT is a Hydrostatic transmission. Unlike the pulley-and-V-belt CVT and the Toroidal CVT that are frictional CVTs, it uses variable-displacement pumps to vary the fluid flow into hydrostatic motors. In this type of transmission, the rotational motion of the engine operates a hydrostatic pump on the driving side. The pump converts rotational motion into fluid flow. Then, with a hydrostatic motor located on the driven side, the fluid flow is converted back into rotational motion.
1014940
Driver Feel
When you step on the gas pedal of a car with a continuously variable transmission, you notice the difference immediately. The engine revs up toward the rpms at which it produces the most power, and then it stays there. But the car doesn't react immediately. Then, a moment later, the transmission kicks in, accelerating the car slowly, steadily and without any shifts. In theory, a car with a CVT should reach 60 mph 25% faster than the same car with the same engine and a manual transmission. That's because the CVT converts every point on the engine's operating curve to a corresponding point on its own operating curve.
Advantages of CVTs
·Eliminates gear hunting as a car decelerates, especially going up a hill.
·Constant, step-less and smooth acceleration from a complete stop to cruising speed.
·Improved fuel efficiency (keeps car in optimum power range).
·Responds better to changing conditions, such as changes in throttle and speed.
·Better acceleration due to less power loss than a typical automatic transmission.
·Better control over emissions due to increased control of the engine’s speed range.
·Replaces inefficient fluid torque converters and can incorporate versions of automated mechanical clutches.
With all of their advantages, CVTs do have some shortcomings. In the U.S., they are still trying to overcome an image problem. The Subaru Justy, for example, was known as a gutless micro-car. Traditionally, belt-drive CVTs were limited in the amount of torque they could handle and were larger and heavier than their automatic and manual counterparts. Technological advances have put CVTs in the realm of their competition- the Nissan Murano's CVT can handle its 3.5-liter, 245-horsepower V6 engine- but first impressions are hard to overcome.
I actually like the one in my Caliber, for what it was purchased for it did it's job. But then I traded that in for my Challenger, and bought a newer work beater.
I have a CVT on my Honda. Actually at the time of purchase, I had a choice of the exact car, one with manual and one with CVT. As a fan of manual transmission cars, I end up paying more for the CVT. A 11:58 decision. The CVT was clearly the better choice for how I was going to use the car.
CVT is not bad at all if you factor in what the car is for, and think about (drive) exactly how the engineers design the car to drive. CVT is smoother and faster in acceleration what's not to like.. And pull like an EV.
The biggest mistake people make in driving a CVT is they smash the gas pedal, and the CVT goes into the horrible state. It's not a sports car, it's not design the be driven that way. If you drive a CVT vehicle in the design sweet spots, it's actually pretty good. It does take a bit of time to learn where that is between the engine and transmission.
P.S. Subaru Justy and Nissan Murano were the early vehicles with CVT. Yes, they were horrible in terms of reliability. Engineers learned a lot 25+ years later, and the advancements will continue to grow.
I had seen many bad reviews on them, especially in the Nissan, and my wife wanted a Rogue. After more research many problems were the early years, and by 2018 seem better with more gearing they put in. Can't remember whats in the 2018 that she bought, but the following year was going even more gears, but the 2018 was to be way better than the earlier ones. I would imagine they will keep getting better and better. She has no problems ever out of it and closing in on 35,000 miles. And gets a good 30 mpg.
Discussion Starter · #5 ·
My wife has a 2020 Hyundai Elantra, in-line 4 cylinder (I.6 liter), with a CVT transmission.
So far, it performs great- gets 41 mpg. on long highway trips. I have confidence because of Hyundai's 10-year power train warranty.
There is one odd thing to get used to. When you try to shift manually, the CVT simulates the shifts.
1014952
And to share my experience on buying a CVT vehicle. Test drive a few. You are a Car Guy, and can "feel" how a car feels.
Here is my story. I know they had two, exact car, color, and both CVT, in inventory. I test drove Car A. Honestly, I was about to change my mind on CVT. That car with 30miles on the clock just did not feel that great in terms of CVT feel. Maybe I'm wrong about CVT transmission. Ok, I was still willing to make the purchase. I saw a scratch on the car. So I don't want this one anymore. Let me try the other one Car B. Car B's CVT felt so much tighter. I would use the word "awesome." I made the deal on Car B. Car B had 12 miles at the time.
25K miles later, my Car B still feel tight. I would buy a CVT vehicle again because of it. If I would have taken Car A. I may not.
I don't know why two exact car felt so different. My point in sharing this is that there seems to be more variation between how CVT feels. Comparing Apples to Apples. At least that's me experience.
19 Challenger R/T Destroyer Gray
I absolutely loathe them. Getting a conventional shifting automatic is increasingly difficult these days in normal passenger cars. Mazda is one of the few, Mercedes another. Both make outstanding slush-boxes. And then there's the FCA in our cars - just fantastic.
Cuda340 always has great tech info! (y)
2020 SPS, M6, Go Mango
I was introduced to cvt on snowmobiles long before I could reach a gas pedal. The constant changing of terrain and engine load, paired with a small two strokes tendency to have little power until peak rpm, made it a logical choice. My mom's jeep compass was the first vehicle I drove with one, and I loathed it. Today's likely perform better, but it was not an enjoyable car to drive.
Good read!
My 2014 Rogue has over 300,00 miles on it and I have never had single issue with it. Literally brakes, tires, plugs and fluid changes and that's it. Remaining my winter driver when I get my '21 Challenger.
As for the CVT - it took some getting used to but its been rock solid.
We have a 2013 Nissan Altima with CVT. No issues. It has about 61-62k miles on it. Been a nice car and gets good mileage.
2015 SRT 392
Thanks for the post Cuda. I was just starting to read/learn a bit about these and your info was interesting.
2020 Scat Pac
Had a CVT on a Subaru WRX - hated it.
Reasons: - Felt weird and uninspiring, so much so that Subaru had it programmed so that you could choose to make it act in discreet steps and feel more like gears shifting.
If you want to mod you can do very little before you reach the tranny torque limit of about 300 ft lbs.
Once it slips you are screwed, non repairable sealed unit.
Same here. So I understand the concept of it, but I have no experience with it in a car.
I worked at Saturn in 1994 when their CVT trans came out. Before the CVT became reality, the idea was there, but there no computer chips fast enough to handle the data speeds required to make it work.
It was also explained to me by the trans engineer that it works the opposite of a "chain" drive, it's not pulling the belt, it's pushing it. When all those plates have pressure applied, it become a solid member. I hope I was able to explain that correctly. It all seems like black magic to me!
Great read Cuda340. I know they have a bad reputation, but I love the CVT in my Altima. The car gets great gas mileage for a car of it's size and merging power onto highways is excellent even though it's only a 2.5L 4 cylinder. You have to make sure you change the CVT fluid every 70K miles, and the CVT fluid is very specific and pretty expensive ($5+ a quart).
1 - 16 of 16 Posts
