1 - 14 of 14 Posts
The top pic..
Bracket is held on with the cradle bolt nearest the bumper
Bottom bracket is where the sway bar end link bolts up.
What ever it is or was used for is NOT factory...Is this a used Challenger? :yikes:
Correct they are not factory. They are under the rear of car. The black brackets are on each side and held in place by the bolt two of the four bolts they hold the rear cradle in place.
The silver bracket is mounted down by the sway bar end link.
No names on them. I think a patent number might have been. I'll look and see.
Hard to say, can you get a pic from the rear showing them both or even all four mounted?
Just a guess but possibly some attempt at a traction device, missing some pieces though?
If it's a patent number you can look in google and get an answer.
1 - 14 of 14 Posts
