1 - 17 of 17 Posts
2021 JEEP Wrangler Unlimited Willys 4X4
Looks like an elbow for a vacuum hose perhaps...
PCV hose looks like
what is the engine in the car?
the PCV valve is screwed into the rear of the passenger side valve cover, and there should be a hose running from it to the backside of the intake plenum. That piece you found looks like it is the piece that plugs onto the intake’s nipple for PVC inlet.
Black dodge challenger sxt 3.6 2016
Discussion Starter · #6 ·
I give up for now, I looked everywhere but everything is in its place, probably will try to find sxt owner and look there, but thanks for helping
Go to post #14 in this thread: PCV Valve on 3.6
And look at the image attached to the post. The elbow labeled “2” in that sketch-up is what I am thinking your item might be.
It would be on the backside of the passenger valve cover on the engine. You will have to stand next to the hood strut and look back behind the engine just below the intake and on the valve cover. You should see a hose connecting them, and there is an elbow in it, or maybe not in your case, that’s what you are checking.
Reactions: Kira
Discussion Starter · #8 ·
Oh thank you, will take a look tomorrow, please check the attached picture if you mean this elbow I have it on its place. By the way I found this thing just behind the washer reservoir, would be funny if it came there accidentally from car service...
Fuel line Auto part Automotive engine part
Both windshield washers work OK?
No, one of them quit and the other is quarantine I heard.
Nevertheless, I gotta say, having homeless guys smear gunk on my windshield with greasy rags every morning isnt all it’s cracked up to be.
I hope they take their time before returning to work on that corner....
2018 Pitch Black SXT
I used to work at a dealer back in the day getting new cars serviced and ready for sale off the truck and occasionally I would find extra parts like that and other things , including tools,in engine compartments. Once found an extra frt. spoiler in the trunk of a Monte Carlo right off the truck.Just a thought, if everything is where it should be..
‘74 Duster 360 4M
AC condensation drain?
Reactions: Kira
Discussion Starter · #16 ·
I believe that may be right, but not convinced that is from your car. See this
But the similar part from your 2016 doesn't look like it (very few actual pictures)
It is should be located under car am I right?
This first looks almost the same.
Discussion Starter · #17 ·
Ok, I checked and it's there, nothing missing. So probably this thing not from my car 😐
But, thank you all for helping! 😅
1 - 17 of 17 Posts
