1 - 4 of 4 Posts
I see the adjust holes labeled for up and down and what direction to turn, but there are no screws or tore screws to turn. Looks like a gear toothed belt like thing down in the hole. Tried to move it with a flat head screw driver, but it would return back to the original position when I moved it.
What's the trick in adjusting these or some special tool needed?
2013 Core
Pull the cup holders off and get a good look at the adjusters. I believe an 8mm socket will fit them.
Sent from my SM-G935V using Tapatalk
Thanks! Pulled off the covers and its a 12mm socket, got them adjusted. The back side of the head of the bolt has teeth in it I guess so that a phillips head screw driver could be used to make the screw turn without removing the covers, but it does work so well that way.
1 - 4 of 4 Posts
