1 - 20 of 24 Posts
I own a '14 rt challenger. I am looking at buying some bigger wheels. I'm digging the 20" Asanti's ABL-11's and was wondering what is the offset i need to run
2010 R/T Classic 6M
What width are you going with? Staggered or square stance?
2010 R/T Classic 6M
Got ya, in that case find the offset for the factory 20x9 wheels and that's an easy solution. If you can't find it I can get it for you
Reactions: HemiGuy7
Discussion Starter · #5 ·
Im doing research and low-key want to run 20x9.5 front and 20x11 back. Im seeing that i need 3mm spacers if i want to go that wide. How do I find the offset?
2010 R/T Classic 6M
i definitely want to go negative offset
For the fronts you will need the offset to be down to around 12mm for 9.5" wheels. For the backs at 11", I'd say around 22mm offset will look good. You know you'll have plenty of poke right? And if you go negative offset you will have a LOT of poke without a widebody.
Reactions: HemiGuy7
2009 B5 SRT8 M6
You definitely can't run negative offset, Stock HC wheels are 9.5" and the offset on them is 18.5mm. for an 11" you are looking somewhere around 21-25mm
Reactions: JD40
2010 R/T Classic 6M
You have to look at the backspacing for the front tire so it clears the control arm. I believe the most it can be is 5.5" on an R/T. That's what it is on my setup and I clear the control arm by ¼" with 255/45r20.
Discussion Starter · #10 ·
Can't i use spacers so it eliminates the rubbing problem?
2010 R/T Classic 6M
Sure you can, but if it were me I'd just get something that fits. I don't like using spacers personally especially in high hp cars. A 20x9.5 with a 12mm offset will fit very well on an R/T. That's what most aftermarket wheels designed for the car have.
Discussion Starter · #12 ·
yeah definitely like the 20x9.5 and 20x11 fitment. Just want to make sure i get that nice wide stance. thanks bro you cleared up a lot of things for me! Just gotta save money now for the wheels and tires
Yeah definitely digging the 20x9.5 and 20x11 fitment, just want make sure i get that nice wide stance. Thanks bro you cleared up a lot of things for me! Just gotta get the funds right lol
2010 R/T Classic 6M
Are you still looking at the asanti's?
2010 R/T Classic 6M
I 100% agree with what he said^. I wouldn't even plug that thing into my car if it were me
1 - 20 of 24 Posts
