SOLD
2x15 mm for the front
2x20 mm for the rear
Hub and wheel centric.
5x115 bolt pattern
71.5mm hub diameter
Used for 1 year, max 5000km. Perfect condition. A little dusty. Never gave me any issues, no vibrations.
Custom made by cnc out of American aluminum in the states. Cost me 260usd.
Selling because I got new wheels with lower offsets.
Work great for oem wheels.
Made by Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
Still have original invoice with matching engravings in each spacer.
They have lifetime warranty from manufacturer. ill ship the invoice with them so you have all the details if you ever need them.
Thanks
Arvin
how far do the factory studs stick out on them? did they clear the wheels or did you have to put shorter studs in the axles for them to clear?
There was more than enough space between the factor studs and the wheel.
Didnt need to do anything, literally took them out of the box and put them on. They come with lifetime warranty from motortech, if anything does ever need to be replaced as well.
