After a bad lifter wiped a cam lobe, I almost have it back together. These two connectors run down the passenger side after the injectors/coils.
Discussion Starter · #2 ·
I just figured out that the two pin connector goes to the mass air sensor. Where does the three pin connector go?
Ok. I found it.
Technically that two pin was the intake air temp sensor. The other goes to the oil pressure sensor just below the the alternator
1025052
did you find it? Oil pressure sensor just above the oil filter toward the front... Temp sensor is to the left
I got it buttoned up. Felt good to hear it fire up again! Thank you .
that's great to hear!
I was wondering how your progress was going
