To find the throttle boost feature, when you select the performance tune (after updating to 9r28) and accept it you get to the next screen that says install diablo tune and under that it says modify tune and you select modify tune and scroll down and you'll see the throttle boost option near the bottom. There you move the arrow up or down the power scale starting in the middle at zero boost and this is where I increased to 10% on my car and it takes even more slack out of the accelerator pedal and gets them wheels to smokin!where is this found on the predator? I have the 9r28 update. That is what the predator says on it when powered up, but it is not listed on my adjustments page?
Are you checking in the Modify Tune or in the Quick Adjust? I don't think it's in the Quick Adjust menu. If it's still not there in Modify Tune then maybe it doesn't work for the 6spd cars but you might wan't to post on the Diablosport Predator Dodge Gas forum and find out for sure. I can't see why they'd have that feature for the automatic/autostick cars only since they both have livewire throttlebody control, right?The last thing on my modify page is WOT spark, I think this booster does not work on 6spd cars.
Yes i am on the modify tune page ,was just told it should be between tire size and rev/speed, its not there on mine?
I have a 6spd with 9r28l loaded and the throttle boost was there. I had to update my cal id first though.
2010 SRT 6spd here to,predator worked without any calid issues. I updated the predator to the 9r28 before ever using it on the car,it went right in and did not ask me to back date calid, but no booster?
Again, throttle boost is nothing more than more throttle opening per percent of pedal travel. It doesn't give you any more power. If your "pig" is slow, push harder on the pedal. You'll get the same effect...When are they gonna get this "throttle boost" update show on the road!!?
I'm anxiously awaiting ANYTHING that will help this pig of a car get more skip in her step!!
Huh? Where are you seeing this?throttle boost is in new 1r08a update crom for 6 spd cars,it was uploaded on the 24th with no notice,i figured i try it as i was waiting for this feature too..ill give a report tomorrow on how it feels...:thumbsup:
From Diablo:
This should get you off the line faster, no?From Diablo:
throttle blade is opening 10% faster than it used to with the same pedal depression speed.
