1 - 20 of 59 Posts
I am not able to keep the 426 cool with the stock R/T radiator, in the summer with AC on in traffic it creeps up to 210-215*, 200 when cruising.
I have come across an 2010 SRT radiator that I can get, but it doesn't look that much beefier than the R/T model.
Comparing it to the radiator I have now, it's maybe 1" thicker across the top.
Has anyone upgraded the R/T radiator for an SRT model?
Was there a noticeable improvement in cooling?
The other option is an aftermarket model, but those start at $600...
any help is appreciated.
edit: this is for a 2010 Challenger R/T
I am running the mishimoto all aluminum radiator and I remember seeing test results showing little improvement on the HC between stock and mish. Search funciton does not seem to be working for me now but I had a long thread about it...I bought mine for <$600...I think it was like $250 on sale. You might need to install some heat extractors like the SRT.
210-215* is not crazy hot. I think you are fine.
Remember this blast from the past?
What do you the temps set for in the tune?
185 low, 185 med, 190 high
whoops. my bad.
edit: looks like aftermarket it is...
heat extractors?
Yeah, the hc hood vents or just swap in a hood from an hc.
I can't due to that large hole I have in the middle of mine :)
Another member on a diff forum mentioned the fact that my R/T is only running 1 fan where the SRTs have two...maybe that is a possible fix for low speed overheating?
an aftermarket radiator
Check out the link listed below:
- Alexis
Discussion Starter #12
The coolant temps before the engine swap never exceeded 190, now it only gets that low when cruising. Maybe it's the 100* days we have here, or maybe the stock R/T radiator isn't up to the task.
I have not seen many performance replacement fan options so I'm guessing the SRT two fan setup must be well engineered.
thinking about this for a replacement
https://www.amazon.com/Dorman-620-039XD-Assembly-Brushless-Chrysler/dp/B07KFZ5NYZ/ref=pd_sbs_263_4/136-8727747-4651307?_encoding=UTF8&pd_rd_i=B07KFZ5NYZ&pd_rd_r=7562e009-de47-4a68-8116-fd2ed18e11ed&pd_rd_w=Jhf1z&pd_rd_wg=dh1DV&pf_rd_p=7cd8f929-4345-4bf2-a554-7d7588b3dd5f&pf_rd_r=XA0BFX8KP46BP0Q3QJHQ&psc=1&refRID=XA0BFX8KP46BP0Q3QJHQ
2015 Challenger SRT
Have you checked RON DAVIS for a radiator...
Discussion Starter #14
sent an email to them requesting a quote. thanks.
probably more fans - the SRT radiator has larger hose diameters - then you get into the water pump outlets are different sizes whether its a 5.7 or 6.1 / 6.4 engine.
FWIW, a 392 will range 203 - 212* I can tell when the fans come on because at 212 will quickly drop back down to with the fans and when the t-stat opens up. On a hot day it will stay ~ 208* at in town cruise speeds
Discussion Starter #16
Running the setup I have that warm would probably cause pre-detonation/knock problems.
I'm going to try the SRT dual fan setup...and possibly relocate the oil cooler.
Discussion Starter #18
Im running a Koyo Brand radiator on my '09 426 stroker engine. I do have the SRT though, with the double fans and heat extractors. No heat issues on my end. The radiator was about $150 on ebay. Amazon.com: Go-Parts - for 2009 - 2010 Dodge Challenger Radiator (KOYO Brand) - (All submodels 5.7L V8 + 6.1L V8 + 3.5L V6) 68050131AA CH3010358 Replacement: Automotive
Thanks.
I am wondering how they list the radiator for all models (SE/RT/SRT) as there is a difference in radiator hose inlet sizes.
The shop I use has a 2010 SRT-8 radiator that I may try if the fans don't work out, I'd need to have it pressure tested tho.
have you looked into Mishimoto or Fluidyne radiators?
those companies make direct fit performance replacements as well as made-to-order options.
I didn't realize Fluidyne is HQ'd not very far away from my town. Then again NC has a lot of aftermarket performance companies. Kooks is another one off the top of my head...
Even mishimoto does not seem to perform any better than a stock radiator. The real benefit seems to be the all aluminum construction.
990273
1 - 20 of 59 Posts
