04 - Vehicle Quick Reference/Maintenance Schedules/Description
MAINTENANCE SCHEDULES - NAFTA AND PUERTO RICO
Oil Change Indicator System
The oil change indicator system reminds you that it is time to take your vehicle in for scheduled maintenance.
On the Electronic Vehicle Information Center (EVIC) equipped vehicles “Oil Change Required” is displayed in the EVIC and a single chime sounds indicating that an oil change is necessary.
On non-EVIC equipped vehicles “Change Oil” flashes in the instrument cluster odometer and a single chime sounds indicating that an oil change is necessary.
Based on engine operating conditions the oil change indicator message illuminates. This means that service is required for your vehicle. Have your vehicle serviced as soon as possible, within the next 805 km (500 miles).
NOTE:
- The oil change indicator message will not monitor the time since the last oil change. Change the vehicle oil if it has been six months since your last oil change even if the oil change indicator message is not illuminated.
- Change your engine oil more often if you drive your vehicle off-road for an extended period of time.
- Under no circumstances should oil change intervals exceed 8,000 miles (13,000 km) or six months, whichever comes first.
Oil Change Indicator- Reset
The vehicle is equipped with an engine oil change indicator system. The “Oil Change Required” message flashes in the EVIC display for approximately ten seconds after a single chime has sounded, to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending upon your personal driving style.
Unless reset, this message continues to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Menu button. To reset the oil change indicator system (after performing the scheduled maintenance) perform the following procedure:
- Turn the ignition switch to the “ON” position. Do not start the engine.
- Fully press the accelerator pedal slowly three times within ten seconds.
- Turn the ignition switch to the “LOCK” position.
NOTE:If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary, repeat this procedure.
At Each Stop for Fuel
- Check the engine oil level.
- Check the windshield washer solvent and add if required.
Once a Month
- Check tire pressure and look for unusual wear or damage.
- Inspect the battery, and clean and tighten the terminals as required.
- Check the fluid levels of coolant reservoir, brake master cylinder, power steering, and transmission, and add as needed.
- Check all lights and other electrical items for correct operation.
At Each Oil Change
- Change the engine oil filter.
- Inspect the brake hoses and lines.
CAUTION:Failure to perform the required maintenance items may result in damage to the vehicle.
Required Maintenance Intervals
Perform Maintenance EveryMaintenance Items(Where time and mileage are listed, follow the interval that occurs first.)MilesKilometersMonths8000130006<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 8,000 miles (13 000 km). 160002600012<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 16,000 miles (26 000 km). <LI style="LIST-STYLE-TYPE: square">If using your vehicle for any of the following: Dusty or off-road conditions. Inspect the engine air cleaner filter; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. Perform the first inspection at 16,000 miles (26 000 km) or 12 months. <LI style="LIST-STYLE-TYPE: square">Inspect the manual transmission fluid (if equipped), add as necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. 240003900018<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 24,000 miles (39 000 km). <LI style="LIST-STYLE-TYPE: square">Inspect the CV joints. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. <LI style="LIST-STYLE-TYPE: square">Inspect the rear axle fluid. 320005200024<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 32,000 miles (52 000 km). <LI style="LIST-STYLE-TYPE: square">Replace the engine air cleaner filter. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Replace the spark plugs (5.7L Engine). <LI style="LIST-STYLE-TYPE: square">Adjust parking brake on vehicles equipped with four-wheel disc brakes. <LI style="LIST-STYLE-TYPE: square">Change the manual transmission fluid (if equipped) if using your vehicle for any of the following: Most of your driving is at sustained high speeds during hot weather, above 90°F (32°C), driving in dusty conditions, or stop and go driving. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. 400006500030<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 40,000 miles (65 000 km). 480007800036<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 48,000 miles (78 000 km). <LI style="LIST-STYLE-TYPE: square">If using your vehicle for any of the following: Dusty or off-road conditions. Inspect the engine air cleaner filter; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the CV joints. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the manual transmission fluid (if equipped), add as necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the rear axle fluid. 560009100042<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 56,000 miles (91 000 km). 6400010400048<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 64,000 miles (104 000 km). <LI style="LIST-STYLE-TYPE: square">Replace the engine air cleaner filter. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Replace the spark plugs (5.7L Engine). <LI style="LIST-STYLE-TYPE: square">Adjust parking brake on vehicles equipped with four-wheel disc brakes. <LI style="LIST-STYLE-TYPE: square">Change the manual transmission fluid (if equipped) if using your vehicle for any of the following: Most of your driving is at sustained high speeds during hot weather, above 90°F (32°C), driving in dusty conditions, or stop and go driving. <LI style="LIST-STYLE-TYPE: square">Change the automatic transmission fluid and filter(s) if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. 7200011700054<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 72,000 miles (117 000 km). <LI style="LIST-STYLE-TYPE: square">Inspect the CV joints. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. <LI style="LIST-STYLE-TYPE: square">Inspect the rear axle fluid. 8000013000060<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 80,000 miles (130 000 km). <LI style="LIST-STYLE-TYPE: square">If using your vehicle for any of the following: Dusty or off-road conditions. Inspect the engine air cleaner filter; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Flush and replace the engine coolant if not done at 104,000 miles (169 000 km). <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the manual transmission fluid (if equipped), add as necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. 8800014300066<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 88,000 miles (143 000 km). 9600015600072<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 96,000 miles (156 000 km). <LI style="LIST-STYLE-TYPE: square">Replace the engine air cleaner filter. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Replace the spark plugs (3.6L Engine). <LI style="LIST-STYLE-TYPE: square">Replace the spark plugs (5.7L Engine). <LI style="LIST-STYLE-TYPE: square">Inspect and replace PCV valve if necessary. <LI style="LIST-STYLE-TYPE: square">Adjust parking brake on vehicles equipped with four-wheel disc brakes. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the CV joints. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Change the manual transmission fluid (if equipped) if using your vehicle for any of the following: Most of your driving is at sustained high speeds during hot weather, above 90°F (32°C), driving in dusty conditions, or stop and go driving. <LI style="LIST-STYLE-TYPE: square">Inspect the rear axle fluid. 10400016900078<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 104,000 miles (169 000 km). <LI style="LIST-STYLE-TYPE: square">Flush and replace engine coolant at 104,000 miles (169,00 km) or 60 months (whichever occurs first). 11200018200084<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 112,000 miles (182 000 km). <LI style="LIST-STYLE-TYPE: square">If using your vehicle for any of the following: Dusty or off-road conditions. Inspect the engine air cleaner filter; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Inspect the manual transmission fluid (if equipped), add as necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. 12000019500090<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 120,000 miles (195 000 km). <LI style="LIST-STYLE-TYPE: square">Inspect the CV joints. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. <LI style="LIST-STYLE-TYPE: square">Change the automatic transmission fluid and filter(s). <LI style="LIST-STYLE-TYPE: square">Replace the accessory drive belt(s). <LI style="LIST-STYLE-TYPE: square">Inspect the rear axle fluid. 12800020800096<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 128,000 miles (208 000 km). <LI style="LIST-STYLE-TYPE: square">Replace the engine air cleaner filter. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Replace the spark plugs (5.7L Engine). <LI style="LIST-STYLE-TYPE: square">Adjust parking brake on vehicles equipped with four-wheel disc brakes. <LI style="LIST-STYLE-TYPE: square">Change the manual transmission fluid (if equipped) if using your vehicle for any of the following: Most of your driving is at sustained high speeds during hot weather, above 90°F (32°C), driving in dusty conditions, or stop and go driving. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. 136000221000102<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 136,000 miles (221 000 km). 144000234000108<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 144,000 miles (234 000 km). <LI style="LIST-STYLE-TYPE: square">If using your vehicle for any of the following: Dusty or off-road conditions. Inspect the engine air cleaner filter; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Replace the air conditioning filter. <LI style="LIST-STYLE-TYPE: square">Inspect the brake linings, replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the CV joints. <LI style="LIST-STYLE-TYPE: square">Inspect exhaust system. <LI style="LIST-STYLE-TYPE: square">Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the manual transmission fluid (if equipped), add as necessary. <LI style="LIST-STYLE-TYPE: square">Inspect the rear axle fluid. 152000247000114<LI style="LIST-STYLE-TYPE: square">Change the engine oil and engine oil filter. <LI style="LIST-STYLE-TYPE: square">Rotate the tires, rotate at the first sign of irregular wear, even if it occurs before 152,000 miles (247 000 km).
WARNING:
- You can be badly injured working on or around a motor vehicle. Do only service work for which you have the knowledge and the right equipment. If you have any doubt about your ability to perform a service job, take your vehicle to a competent mechanic.
- Failure to properly inspect and maintain your vehicle could result in a component malfunction and effect vehicle handling and performance. This could cause an accident
Failure to follow these instructions may result in possible serious or fatal injury.
