1 - 20 of 50 Posts
Most people have gone for the "JET" brand, but I was told Thursday that the one from Razors Edge Motorsports is exactly the same thermostat but 10-12 dollars cheaper. The gent I was talking to said they could have been manufactured in the same plant with different branding.
Maybe some of the old timer forum guys can comment better on this.
...and did YOU know that by holding "ALT" and typing "167" you can make the little "degrees" sign?
As in "Jet 180º thermostat"
:browsmiley: :thumbsup:
I installed a Jet 180 today. Easy do - 20 minutes. Perfect fit, "weep hole" at 12 o'clock position, good seal with the gasket. Reset the fans with my Predator - went for a good drive in/out traffic, highway, etc. Ran significantly cooler - no issues, no codes, worked exactly as advertised. Pay a few bucks (its less than $40) and get a quality T-stat.
Great tip! Ive always used alt 248 so my 180° t stat is on order as we speak! Im not sure if it comes with a small hole in it, but ive always just drilled a 1/8th hole in the t stat outer rim to get rid of air pockets.
Just fill and go.
Take it easy
Discussion Starter · #13 ·
Looks like the jet 180 is the way to go.
Thanks For the info
Jack
I believe the JET is the same as the Motorad. I ordered mine from JET but it says Motorad on it.
Sent from my iPhone using Autoguide
i have the autozone one and one from napa. the autozone 4128 ran a little cold and threw codes. the napa one ran about 183 to 185 degrees and doesnt throw codes in my car. I wouldnt be concerned with the weep hole. Ive never had a problem with non weep hole tstats before
My jet failed after 1 year so I just replaced it with 4128 from AZ. Both the jet and 4128 throw the coolant codes for me, but I just clear them with my predator.
The $7 one from Napa isn't going to have a bypass on it. That's why the Jet costs a bit more. Not all thermostats are the same.
Yeah, what he said..
You also want to make sure you bleed the system correctly if you're a DIY'er. You leave air in the system you'll be asking for trouble. The bleeder is by the TStat housing facing the front of the car with a hex wrench fitting.
1 - 20 of 50 Posts
