Besides 20 more cubic inches, why does the 6.4 make so much more torque and hp over the 6.1?
no. no magic.Sooo, it's not magic?
I stand corrected. Guess I heard wrong somewhere.Its not a bored 5.7. Everything about it is brand new. The code name for it is the apache. The heads are very similar to the eagle heads but with larger valves. The stroke was increased to 3.72. The bore was increased to 4.09. The cam is fairly large and with vvt they can make a ton more low rpm power while maintaining upper rpm hp. The manifold has active runners which is also helpful. Its just a bad ass engine to sum it up.
I love when u talk dirty to us...Its not a bored 5.7. Everything about it is brand new. The code name for it is the apache. The heads are very similar to the eagle heads but with larger valves. The stroke was increased to 3.72. The bore was increased to 4.09. The cam is fairly large and with vvt they can make a ton more low rpm power while maintaining upper rpm hp. The manifold has active runners which is also helpful. Its just a bad ass engine to sum it up.
