Looks ok to me
But still not far enough out to the fender for me I think 275 would bring everything out flush and look much more aggressiveIncorrect I've been running half inch spacers for over a year and never had an issue even at +100mph
That’s a little bit too much bulge , problem you’ll have is the tire kinda folding under cornering. Again , many people do it , I usually won’t go past the recommended width by more than 10mm.Looks ok to me
That is terrible, and only a matter of time. The limit is actually about 8mm. When you tighten a lugnut , or any nut for that matter. The formula for proper fit is the nut should engage as many threads as the diameter of the bolt. In this case , your lug should engage 14mm of threads. You are not getting that with 13mm spacers. I know this for fact.Incorrect I've been running half inch spacers for over a year and never had an issue even at +100mph
How do you feel about the replica hellcat wheels that are 20" up front and 22" in back. 10" in back and 9.5 up front I think this might get me closer to the look I wantThat’s a little bit too much bulge , problem you’ll have is the tire kinda folding under cornering. Again , many people do it , I usually won’t go past the recommended width by more than 10mm.
I'm getting at least an inch of stud or more so I'm sure it's over 13mm and I keep a constant check on the tightness as well. I'm a heavy modifier to cars and a half inch spacer is prob the smallest spacer I've ever ran. Lol never had issues. Most issues come from people who let there buddies do it for them in the backyard I have a full shop and do custom workThat is terrible, and only a matter of time. The limit is actually about 8mm. When you tighten a lugnut , or any nut for that matter. The formula for proper fit is the nut should engage as many threads as the diameter of the bolt. In this case , your lug should engage 14mm of threads. You are not getting that with 13mm spacers. I know this for fact.
Your best bet is 100% getting the correct wheels. I personally run 20x9 245/40/20 up front and 17x10 315/50/17 in the back. I also run a 13mm spacer in back , before I changed out to longer studs , I 100% did not have 14mm of thread engagement. I had about 3-4 turns of the nut. Should be closer to 8 full turns.How do you feel about the replica hellcat wheels that are 20" up front and 22" in back. 10" in back and 9.5 up front I think this might get me closer to the look I want
