I have a 13 RT. I ordered a set of Asanti 20x8.5 wheels with a +20 offset for all 4 corners. What is the widest tire I can put on it without rubbing? Im new to the forum and new to being a dodge owner as well..
Your stock wheels were 8" wide, so these Asanti's aren't going to allow much wider tires. The offset on the Asanti's will be perfect though.
Reactions: Nelson3r3
Will a 10" wheel with the same offset fit?
I have a 2015, my quarters are rolled from the factory, I have 10.5" wide wheels, +22mm an I run a .25" spacer and run 315s. I do not know what your car needs as far as offset but the widest you can run are 305 without rolling your quarters. (From what I have read) My drag tires are the same size as my street tires.
1002531
