1 - 2 of 2 Posts
Was thinking of steeling the wheels from my 08 Cobra (which have nitto 05rs on them) and mounting them to the scat to go the the track. Will it work?
5-lug, 4.5" bolt circle
7.125" backspacing
45 mm offset
18" x 9.5" wide
24 lb each wheel
you will need wheel adapters..your offset is too high. A 1 inch adapter will work (making it more like 20mm). Also make sure the hub is not too small to fit on the car..I am not sure of the 08 but later years, the hub diameter is smaller than 71.5.
1 - 2 of 2 Posts
