1 - 20 of 36 Posts
You can enter your VIN# in these links to get a pdf copy of your Window Sticker and/or Build Sheet. Be aware Window Stickers are generally only available for a couple of years. If no longer available you will get an error message "Sorry, There is no window sticker available for this vin" . Make sure VIN# is all CAPS
Window Sticker and Build Sheet
Add your VIN# to the end of these links, all CAPS
Window Sticker
For Canada, some say this works when others do not
https://www.dodge.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
https://www.chrysler.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
Use your VIN number to get Dodge Window Sticker
(Scroll down a bit to box to enter VIN#, then scroll to bottom of results page, hover over Window Sticker to reveal Download or Print options upper right)
Build Sheet
I was cleaning my new Challenger recently and discovered a build type of sheet in the rear pocket of the passenger seat. The dealer had my original special order window sticker laminated.
Good thing dealer didn't see it or they would have thrown it out.
Ah so we could not make my post a sticky? :p Oh wait, I don't think you were a mod back then. :unsure:
I was able to get a copy of my window sticker for my 2018 Charger GT AWD, only problem is that the car was sold in Canada and the window sticker is in French..... o_O
Discussion Starter · #9 ·
This was one of these lookups, or you had a physical copy sent?
Discussion Starter · #11 ·
Interesting, if you want, PM me your VIN#, I'll take a gander
Discussion Starter · #13 ·
Mon Dieu! Indeed, it's Surrender French everywhere. A translation is a hoot, I will send you one :) Sorry
Reactions: CNTLOSE
2010 Challenger R/T Classic
Pretty sure this is only available for 14+ cars now. Just FYI.
Are you saying the lookup does not work for older cars? I just looked up a 2009 300 the other day.
Just looked up a 2009 and 2010 challenger and no window sticker but the build sheet works.
Discussion Starter · #20 ·
It's hit or miss with pre-2015 for Window Stickers, Build Sheets usually available much longer, although it's not uniform either
1 - 20 of 36 Posts
