Hello all!
I have a 2012 Dodge Challenger. A couple of a weeks ago I turned on my turn signal and my wipers cut on and stayed on. I ended up pulling the fuses in the wiper box to cut them off. Should I try replacing them with new ones or is this a wiper motor issue? I would like to try and fix them myself if this is an easy fix. Any advice would be greatly appreciated!
Charger 392
I would first disconnect the battery in the trunk for a good 15-20 minutes to reset the BCM module. See if that works
Welcome to Challengertalk ;) Perhaps relay?
1002368
Does it change to intermittent if you adjust the switch, or always runs constantly? Slow speed or fast speed? Change if you switch speeds with switch? Does the washer work?
Reactions: SRT8 Mike
In addition to ^, I would see if you can unplug the wiring for the turn signal stalk, that might have a short/stuck connector in it.
Also do you have Rainsense? (was that available in 2012, my Grand Cherokee has it) But that still turns off entirely.
