1 - 4 of 4 Posts
Hi,
Wondering where is the easiest spot to pass some small wires thru the firewall preferably on the passenger side ?
I have the 2015 SXT Plus model The wires are for some LED's, so nothing big
thanks
isn't there a grommet somewhere to sneak then through? Did you look yet?
Sent from my SM-G920V using Tapatalk
I will tell you how I did it but it is on the driver side under the brake booster.There is a large rubber plug with wires running through it.It is large enough to make a small hole to run wires through.I took a stick type ink pen,removed both ends and the "guts".Cut one end at a sharp angle to make a point on it and jam it through the rubber plug.Run the wires through the hollow ink pen.The wires will come into the car near the brake pedal.Just run your wires from there to the passenger side.
1 - 4 of 4 Posts
