1 - 10 of 10 Posts
Hello,
i search for the wiring diagram for Light ECU to Taillights ( SRT 2016 )
Someone have this diagram ?
Or someone know where i can get them ?
Thank you !
I have diagrams for a 2015 which I pulled from Alldatadiy.com ($29/year subscription based site which contains some extra stuff the service manual does not).
Otherwise, you can go here and search for the pinouts and wire colors.
Mopar Connection Repair Kit
Oh similar to the euro mod (I saw ECU and was thinking PCM/BCM)...I have not run across any schematics that show how to do the conversion. I thought the outer ring light bar would require new LEDs to give the dim and bright mode illumination? Although if the signal is PWM then the driver circuit would require modification. :dunno:
Do you know 100% - is there a PWM Signal to the outer ring ?
Here in Germany make 2 Companys this conversion + 1 Company in Poland
But there give no Information to me
Answer from Poland Company:
In our lights stand lights are dimmed bit vs stock - to make stop brighter.
It's still enough bright at low light and some bright in sun.
look:
https://cloud.tapatalk.com/s/5af52deeaa06d/VID-20160818-WA0003.mp4
Only way to know for sure is to measure voltage output with an o-scope. The Poland company makes it sound like the LEDs are not changed but the signal is altered. I have not messed with the tail lights (only head lights).
Measurement is the only way to be for certain as I doubt the companies that do this mod would openly share this information.
1 - 10 of 10 Posts
