Has anyone did any research on seeing if a Hellcat supercharger would fit a 5.7? I'm pretty sure that they'll start coming up for sale with low miles on them soon, and I had a thought.............
It would sure be a head turner for sure.
Doesn't the HC SC use a mass air flow sensor? You would also need the pulley/drive belt set-up. It also would put out a lot of boost for a 5.7 so forged parts are a must.
Ya don’t bother. They run 12 lbs of boost
The belt system is different all together. The inner cooler is specific ect
Plus - you'd have to come up with a different way for putting oil into the engine.
5.7s have the oil filler passing through the 5.7 intake.
On Hellcats, the filler is in the valve cover (different design).
I suspect the head has a different bolt patter to accommodate the S/C and the oil fill port that's on 5.7s / 6.4s is omitted on HC heads.
