Just took the Challenger to the dealership for wheel balancing....snow tires start to wobble at 120kph.
Summer tires did too but at 140kph+. They showed me the car up on the hoist & made me press on both front wheels side to side.(3 & 9 O'clock )
Driver side showed lots of play/wobble, passenger side had less play, but some nonetheless.
So bottom line, this would cause a wheel shimmy/vibration, correct ?
I was quoted CAD$ 540 for parts & 3 hours labour (plus tax)
This is for 2 inner tie rod replacement.
This sound good to any of you ?
Thanks in advance for any input/advice...:grin2:
I don't think worn inner tie rod ends would cause a wobble or shimmy. They aren't spinning therefore any problem they contribute to won't be dependent on wheel speed. However there is a *chance* it could make a shimmy more noticeable, if the tires are wobbling in-out rapidly. But if it's that bad, you have another problem. More than likely your tires are still out of balance, or you have snow/mud buildup in the rims (Check behind the spokes, it likes to hide and collect sometimes), or your tires have excessive runout or stiffness variation. A defective or separating tire could cause that. Unfortunately there is no way to say for sure without checking the car over in person. We can only guess.
Reactions: jjpogi
Hmm, so in addition to the inner tie rod replacement, I should also get the tires rebalanced anyways ?
This will be the 2nd time said dealership will try to balance this set of tires....Hunter Roadforce balancing perhaps ?
:dunno:
UPDATE: Just went ahead & ordered Moog Inner & outer Tie rod ends from Rock Auto
I will update again once parts are installed (at another speedshop). Thanks for looking.
:11:
Final Update:
Got the Moog Inner & outer tie rod ends from Rock Auto.
Also got the front winter rims balanced plus a 4 wheel alignment.
Install & balance/alignment done by a new speedshop recommended by a buddy.
All cost below the price$ quoted by the stealership.
Car now runs smooth until the winter tire advised top speed of 180 kph.
p.s. This all on a 7 yr old SRT with only 46,000km (28.5K miles) on the odo :deal:
Happy ending ! :banger:
Final Update:
Old thread but how are those moog tie rods holding up? Just got some for myself but the price difference from oem is...worrying lol
$18/r for the inners and outers
Went with these instead...better looking and says only fits srt’s but oem part number cross overs say it will fit, will update
Moog makes quality parts for a long time ;)
