If I delete the mid mufflers on my 18 5.7 with the active exhaust will it interfere with it? To my knowledge the valve actuators are near the end of the system by the resonators, far after the mid mufflers, any advice?
The valves are near the mid mufflers, not at the rear resonators. You need to crawl up under the car and look for yourself.To my knowledge the valve actuators are near the end of the system by the resonators, far after the mid mufflers, any advice?
You’re right that they’re closer to the mufflers than the resonators, but they’re still “after” the mid mufflersThe valves are near the mid mufflers, not at the rear resonators. You need to crawl up under the car and look for yourself.
My valves have already failed and been replaced twice now, and the newest set have already failed again so I’m no longer worried about the problem as it seems bound to happen again. They still operate, just with a horrendous rattling noise when either cold or when they’re in the closed position.It will affect your warranty though, if your valves fail which quite a few have done, the dealer will likely deny coverage with a muffler delete.
