Z Automotive BurnBox
Line Lock: Using one of the cruise control buttons/lever (depending on vehicle model), the BurnBox G2 uses the ABS valves to hold the vehicle with the front brakes so you can hit the gas and do a perfect burnout as long as you wish, with no wear on the rear brakes. No plumbing required! This is a perfect alternative to the traditional plumbed-in solenoid type line lock/roll control. Super simple and cannot be detected! Gone are the days of plumbing in external solenoids in the brake system, having to bleed the brakes and run wires through the firewall to a switch.
Light Show: Using the keyfob or steering wheel buttons, turn on a light show that flashes the exterior lights in 9 different patterns.
6 pre-set patterns
3 customizable make-your-own patterns
Z Automotive Programming Utility (for Windows PCs only) is used for firmware updates and for configuration:
– Choose which exterior lights are included in the patterns
– Create your own patterns
– Choose which patterns to include or remove
– Choose which pattern to start with
– Save custom shows to file or load them from a file
– Can be enabled for in-motion use for authorized users and off-road parade use; email tech support for instructions
INSTALLATION IS A SIMPLE MATTER OF PLUGGING IT INTO THE DIAGNOSTIC OBD2 PORT WHICH IS LOCATED ABOVE THE PARKING BRAKE.
To Order:
2015-2017 Challenger/2011-2017 Charger/300 (All but Hellcat): http://www.speedlogixstore.com/product-p/burnboxg2.htm
2005-2014 Challenger/Charger/300/Magnum: Z Automotive BurnBox G1 2005-2014 Challenger/Charger/300/Magnum
2015-2017 Challenger/Charger SRT Hellcat: Z Automotive BurnBox Hellcat 2015-2017 6.2L Challenger/Charger SRT Hellcat
2013-2017 RAM 1500: Z Automotive BurnBox RAM 2013-2017 RAM 1500
Thanks
Chris
The 2015-2017 Challenger/2011-2017 Charger/300 (All but Hellcat) address is wrong ;)
2015 Challenger SRT
Whether you get the BurnBox from Speedlogix or from Z Automotive , it's a great product...Works great...
