1 - 1 of 1 Posts
Z AUTOMOTIVE NOESP 2008-2013 CHALLENGER 2005-2010 CHARGER/300/MAGNUM
Looking to drift, do donuts or great burnouts in your Charger, Magnum, 300C or Challenger? Then you’ll need to overcome the Electronic Stability Program in your vehicle.
The NoESP module installs in about 20 minutes using four wires that connect behind the radio bezel and shifter bezel. Once installed, it’s completely hidden and does nothing until you activate it.
Press and hold the ESP button for five seconds, and the NoESP goes into action. The ESP/BAS indicators will light in the instrument cluster, as well as “Mr. Squiggles,” indicating that the ESP system has been disabled. Traction and Yaw control will no longer hinder your fun until the next time you start the car. Combine with a TranZformer and ESP can be turned back on without restarting the car.
It’ll work on all Charger, Magnum, 300C from 2005 to 2010 and Challenger from 2008 to 2013 equipped with ESP.
It is not typically installed in SRT8 or STP models as they already include this feature.
To Order: Z Automotive NoESP 2008-2013 Challenger 2005-2010 Charger/300/Magnum
Thanks
Chris
1 - 1 of 1 Posts
