1 - 20 of 32 Posts
Challenger Scat Pack
I have a Tazer up for sale. Nothing wrong with it at all. Just got rid of my 2015 Scat pack and no longer need it. Has been updated with the latest firmware.
$200 and it's yours. I'll pay shipping which will cost nothing anyway. Priority mail.
Accepting square cash
PayPal
Do you know if this will this work with the new 2018 Uconnect 4 "7" screen and what will it do?
Thanks!
Thanks!
This one will not work with the new 2018. That model needs the double bypass to work. This one just plugs right into the OBD2 port and that's it.
Ok, Thanks.
I wonder what features it unlocks with this Uconnect 4 "7".......do you have a phone number for TAZER?
I looked online and I found one site that sold it but they only accepted Text messages on their phone number, crappy customer service.
Ok, Thanks.
I wouldn't be able to answer that. You'd have to go their route or wait for someone else to respond to this if they're even paying attention.
Ok, Thanks.
2018+ Models: Due to the addition of a new security module, the*DOUBLE BYPASS KIT*is REQUIRED for the Tazer to function!
Feature enable: The Tazer can unlock SRT Drive modes including Track, Valet, ECO (2015-18 Scat Pack), enable factory Sport Mode (5 speed and 8 speed), SRT EVIC Performance pages, and SRT performance pages* in the Uconnect radio. Enable paddle shifters if you add the factory paddle-equipped steering wheel. Enable factory fog lights and backup camera & grid lines. Disable TPMS.* Change DRL’s. Enable Shift Light on 2015+ (6.4L). Disable in motion navigation lockout. Disable seatbelt reminder chime. And more, see installation and operation manual or*FAQ/Feature Chart.
Line Lock:*Press 2 steering wheel buttons while stopped, and the ABS valves will hold the vehicle with the front brakes so you can hit the gas and do a perfect burnout as long as you wish, with no wear on the rear brakes. No plumbing required! This is a perfect alternative to the traditional plumbed-in solenoid type line lock/roll control. Super simple and cannot be detected! When Line Lock is in use, it temporarily disables traction control and for AWD cars, keeps the car in RWD mode.
Light Shows:*Using the keyfob or steering wheel buttons and added dash menu, turn on a light show that flashes the exterior lights in 9 different patterns – there are 6 pre-configured patterns and 3 make-your-own.* Perfect for car shows and parades. (can be unlocked for in-motion use, only for legal emergency use.* Contact tech support for instructions)
Startup Drive Mode:*Like driving in Sport or Track mode every time you get in your car?* Tazer can set the startup drive mode for you, so you don’t need to switch modes every time you get in the car.
Auto StopStart Disable:*If you have a Grand Cherokee or Durnago with Auto StopStart, you may find it annoying and want it to default OFF.* The Tazer can do this for you, no need to press that disable button every time you start the car.
Steering Wheel shifting**(SWS): Allows you to use your steering wheel’s cruise+/- buttons to manually control gear shift while keeping your hands on the wheel. SWS mode is enabled after placing the vehicle in AutoStick mode using the console shifter. Once in AutoStick, use the cruise buttons to shift (only when cruise control is turned off)! This feature can be enabled or disabled at any time using the steering wheel buttons.
AutoUpshift**: Set your own shift points when in AutoStick – Using steering wheel buttons or ZPU Utility, dial in any RPM for upshifts in AutoStick mode – perfect for high-power high-revving track use. This feature requires that “sport mode” is enabled (2012-2014 only).
Peak RPM Display:*Will display actual shift RPMs after each shift – great when adjusting AutoUpshift to squeeze every last bit out of that high revving cam, or to check what RPM you hit when shifting manually.
0 to 30 and 0 to 60 Timer: Will display 0 to 30 and 0 to 60 times on EVIC display. Good for the 2011’s that can’t enable SRT pages.
Force AWD modes: On AWD models, force the AWD system to stay in RWD or AWD, instead of letting the car decide on its own. Good for racing, drifting, etc. Or set it back to “normal” whenever you wish.
Reset Adaptives:*Will reset TCM adaptives any time you wish with a simple push of the “BACK” and cruise on/off buttons.
ESP full on/off: Press and hold the ESP button for 7 seconds to TOTALLY disable the ESP, ABS, AWD systems. Press and hold again to turn it back on.
Button Remapping: Use the Adaptive Cruise distance buttons (when ACC is off), or install “Aux” buttons or viper cruise button bank and map the buttons for quick access to many of Tazer’s functions.
Video Inputs (RA3/4):*The tazer can enable extra video inputs for a front camera or video player., or both.* The*AV Cables*are needed to add the video and audio feeds.
*LINKS
OUBLE BYPASS INSTALL GUIDEINSTRUCTIONS TO INSTALL AUX BUTTONSADD VIDEO SOURCES TO RA3/RA4 RADIOS
*Uconnect performance pages on 8.4? Uconnect only (2012-2014). EVIC SRT menu and Sport Mode are available on the 4.3? screen.
**not on 8-speed vehicles.
*LINKS
Thanks for that info DROXX, but are you sure the performance pages you listed will work with the new 2018 Uconnect 4 with the "7" screen??......I don't have the "8.4" screen.
Got a 17 Durango GT and saw it can disable the stupid auto engine stop...but I will have to get this taser and another piece in order for it to be compatible?
Discussion Starter #16
That I'm not sure of. You may have to email or contact zautomotive.
I also had to sell my 15 Challenger Scat Pack. I had just "married" my Tazer to my car. Now the car is long gone and out of state. I sold the Tazer but the guy returned it because it was still "married" to my car/VIN. How do I now fix my Tazer so that I can sell it? I asked Zauto if reloading an old software version would work? I am waiting on a response from them.
1 - 20 of 32 Posts
