1 - 14 of 14 Posts
I am hearing the zf rear ends have the ring gear welded to the carrier. I also have heard talk of some guys going to a 430 ratio. Anyone know if the 430 is actually available?
Sent from my LG-H918 using Tapatalk
The ZF is welded, so you do have to swap the whole unit.
You have four ratios:
2.62 (Hellcat Auto)
3.09 (Auto)
3.70 (Hellcat Manual)
3.90 (Manual)
If you have a 3.09, a move to a 3.70 could work well for you.
2.62 (Hellcat Auto)
3.09 (Auto)
3.90 (Manual)
Thanks. Yea I seen those ratios were available. Did not know if there was a 4.30 available from Mopar performance or not. I have m6 with 3.90. More gear would be nice.
You want more gear?:eek2:
my 2015 rt 6m with 3.90 gear has the goodyear fi tires which are 28.7 dia...the gear charts say that is a 3.76 actual ratio.....I need new tires and am looking at the general g max 05 in 245 40 zr20 size which is 27.7 dia...the gear charts calculate that to a 4.04 actual ratio.....I think that would help get the car moving quicker....what is stoping me is the smaller side wall maybe causing more wheel hop than I have now ? the g max a/s may have a softer sidewall than the fi supercar tire which may actually decrease wheel hop...I am not sure...may be an option for you to get more gear
You are correct. Less sidewall is a problem on launching. More side let's the tire work. I run 275x45x20. They are 29.5" tall. This isn't a huge change but these things are over 4000lbs. It takes some gear to get these things to launch, yes I know the hellcat has same gearing if 6 speed, 3.90 but 700 hp makes a difference. Imagine if ya put some gear in that!. Been around fast cars forever, I'm 55, been there done that. This car I purchased for a retirement project . So it will get a lot of go fast goodies as I am planning to track the girl. I will in the end run a smaller diameter rim with a 29 to 30" tire on the rear but gearing is an issue. The 275x45x20 has helpeda ton on wheel hop and this little engine pulls this tank to constant 4.9 0-60 but you can't launch more than 2000 or your up in smoke but it's 10000% bettet than the f1 trash. Since we are limited to the 3.90 we will just have to get more power lol. That is a double edge sword though more power harder to get traction but with a tall sidewall drag radial or stragglers slick for the track we will be good.
Bringing this thread from the dead as I recently swapped my diff and cracked open the old one only to find the ring gear bolted to the spool with no signs of it being welded.
991873
The diff is easy to tear apart and assemble so I wonder why there are no kits to rebuild them? I mean why would FCA have replacement bushings for the front then?
991875
991876
Also wonder why no one has made full metal snubbers (#3 in pic above) as is done for the rear cradle bushings to limit movement?
991877
View attachment 991875 View attachment 991876
I found it very odd when I heard they were welded. Was that ever confirmed? I think this is the Myth buster thread! It may be time to check with US Gear on any updates with availability on gear sets.
Sent from my SM-T350 using Tapatalk
When I inspected the ring gear I saw no visible weld from the gear to the spool. I was tempted to unbolt the ring gear but I scrapped it already.
They said it was bolted and welded. If you look at the ring gear where it mates to the carrier it looks to me it's got a nice weld around it, but not to clear zooming in on Pic.
Sent from my LM-G820 using Tapatalk
The spool/carrier is not round like the ring gear but irregular...you can see it go up and down around the bolts. That fillet is part of the ring gear not carrier. Dang...I knew I should have unbolted it.
Just saw a thread on the HC forum where someone state the 2.62 were welded but not the 3.09?
They sell a gear for the zf. Took me a while and lots of research to find the part #. US gear made them. Not sure why they stopped but heres the part # for 4.10's. They are out there somewhere. Im looking. 03-487410 LC/LXISF
So this would be another data point suggesting the ring gear is not welded to the carrier like I found when I cracked open my old unit.
1 - 14 of 14 Posts
