Interior plastic scratches
12K views 20 replies 11 participants last post by  2Marks
Don’t use a heat gun it’s a good way to ruin the plastic and have it dry out prematurely. It’s not something I would ever recommend. It works by heating plastic to the point the oils come up to the surface pulling the oils out of the plastic which is why it causes premature oxidation.
With no pictures it’s hard to tell you what you can do. With mild scratches you can use a magic eraser that can minimize them but that’s about it. I don’t know of any method that could actually fix it. If you go this route do it gently, if it doesn’t work then I think your only option is to replace.
Reactions: SFCR
