Little shaker mod from Scaila Motorsports
28K views 92 replies 20 participants last post by  icecoldmn
so after a month of having the kit on and 2 weeks of the "new" lower spacer kit it is still squishing the rubber seals at the front corners and starting to wear thru the paint on the shaker opening . i think ill need to swap the front nuts out like the other poster.
overall i love the look but not sure if the juice is worth the squeeze, ill report back once i give it a couple weeks with the smaller front shaker nuts as it is obviously the tall nuts that are hitting the hood corner on the passanger side when the motor flexes.
pete
Yes, please keep us updated. Do you know what size nut it takes?
I was going to put my kit on today while doing an oil change, but having second thoughts now. I think my kit came w/ the smaller magnets but not sure.
I found some stainless cap nuts (pn# 887480118087) at HD that are about half the length of the stock Mopar cap nuts. They seem to work fine, but time will tell if they rub.
1023440
1023441
