Do not want to wear out helpful folks, but am planning on installing door speakers today and the next thing will probably be to alleviate gross ignorance on what to do with the amp and digital interface. If you have any helpful hints they would be appreciated, I am wondering:
My comments are in-line below:
1. Where are people putting new amps and digital interfaces?
I personally put the external amp and DSP in the trunk, where the spare tire would normally go:
I cut a board to fit into the "foam" think in the trunk, wrapped it in an inexpensive material used for this type of thing and secured the board using a spare-tire hold-down bolt (I documented this elsewhere on the forum - can find and post a link if interested)
I installed the PAC AmpPro 4 in the area underneath the steering wheel (it connects to the back of the OEM head-unit).
2. What wire routing works between the new amp and the battery, new hole in firewall?
If you install the amp in the trunk, the power wiring to the battery is SUPER easy since the battery is also in the trunk.
3. Where do you splice new speaker wiring from amp into existing speaker wiring?
I used the PAC harness mentioned above, which allowed me to run speaker wires from the amp in the trunk to the area where the stock amp is located. Using the PAC harness allowed me to avoid running speaker wires up through the dash and into the doors - so I used the new speaker wires from the amp to the OEM amp location and the the stock speaker wires from the OEM amp location to do the door and dash speakers. The stock speaker wires are fine for most normal aftermarket power levels. Plus, with this method, I didn't have to cut ANY stock wires. Since the amp is in the trunk, I ran new wires from the amp directly to the rear speakers (easy, short runs).
4. Is there documentation publicly available on the oem stereo system (wire routing, component location, etc) without me spending whatever they charge for a shop manual?
I have the Crutchfield docs, but you probably already have those. There are also some libraries that allow access to Chilton guides, but honestly, I didn't find any of that was necessary - especially if you use the PAC harness mentioned above.
I'd
highly recommend the PAC AmpPro 4 to integrate an aftermarket amp. You really don't want to use the speaker-level outputs from the OEM amp, because those signals are EQ'd for the factory speakers, may use allpass filters, may have bass roll-off at higher volumes, may cause integration-related issues with phone calls, you'd also be amplifying any OEM chimes, etc, etc, etc. The PAC AmpPro 4 basically puts the OEM head-unit into a "low-level" output mode and gives you
clean, flat line-level outputs directly from the OEM head-unit. Don't have to worry about any summing, de-EQ, bass roll-off, OEM integretion, etc. The PAC AmpPro devices are
fantastic to have - if they are available for a car you have (like the Challenger), it's a no-brainer to use it. It will also give you a subwoofer output, a bass-knob, an optional optical digital output, you can configure the Bass/Mid/Treble controls, adjust the "minimum volume level", reproduce OEM chimes, etc. It adds cost, but makes your life so much easier and allows you to use ANY aftermarket amp. I really can't recommend it enough.
Lastly, while I wanted a true "SQ" audio system, I didn''t want to deal with a big subwoofer box in the trunk. I decided on a JBL BassPro SL fully-integrated under-seat subwoofer. It's a self-contained subwoofer with a 125W RMS amp and a low-profile 8" subwoofer in a box that is less than 3" in height. It fits really well under the passenger seat and
really gives you the low-end that you'd otherwise be missing without a dedicated sub.
I think it is a major pain in the ass and this ain't my first rodeo on similar stuff. I think/hope we will get to a point where somebody details the installs so it is paint by the numbers rather than try to become part audio engineer and part installation technician just to figure out how to get the job done.
The PAC AmpPro 4 is your friend here - takes care of all of the "OEM integration" complications for you and gives you aftermarket-line line-level outputs from you OEM head-unit. At that point, it's no different than adding an aftermarket amp to an aftermarket head-unit.
Hope this helps - don't hesitate to ask if you have any other specific questions.
