Has anyone put a set of 20" cragar s/s wheels on their Challenger? I didn't know if this was basically the same looking wheel that comes on the Challenger classic? If so, pictures anyone???
Answer - I don't recall the specifics, however at the time I contacted the outlet I got them from (Summit Racing) and they provided the info I needed on the lug set (they had them in stock, so I just ordered them). What they sent fit perfect. I didn't get any locks -so can't speak to that. They do sit down pretty far inside the lug holes so you'll also want to get a thin wall socket and an extension to keep handy for tire rotations and such.HemiFan,
I'm getting ready to order the same wheels as you. Can you tell me what lug nut set you got to go with your wheels, and what lock set you got. The Cragar site didn't what goes with what wheel. Thanks
ThanksAnswer - I don't recall the specifics, however at the time I contacted the outlet I got them from (Summit Racing) and they provided the info I needed on the lug set (they had them in stock, so I just ordered them). What they sent fit perfect. I didn't get any locks -so can't speak to that. They do sit down pretty far inside the lug holes so you'll also want to get a thin wall socket and an extension to keep handy for tire rotations and such.
Got mine from Americas Tire. Cost for rims and tires was $2000, they didn't mark up from Crager. I got Nittos on my car with warranty on the tires (A tire got punctured 1 month in and they took care of it).
For pics see this thread:
http://www.challengertalk.com/forums/f6/washed-waxed-107370/
Nice! also like the exhaust tips!!! Black is good!Here's some pics - 20" Cragar SS 610Cs. 5.5" backspace, 13mm offset, 115mm bolt pattern on my SRT8. Wheels are one of the most "personalized" things you can do from an aftermarket appearance perspective. Ultimately, it comes down to what "does it" for you - as long as you're pleased with the look, that's what really matters.
In my case, I wanted something "retro" - the Cragars worked for me. I also like the look of chrome on black. I personally think the modern Challenger looks better with a low-profile tire compared to going totally "old school" (smaller rim, higher sidewall) - but again, that's just me - I'm very pleased with how it looks with the Cragars. Lots of options on aftermarket wheels, so take your time and choose what does it for you.
BTT as I would like to know the answer to this question, too. Sadly, my stock R/T rim look like crapJust to verify. So a 20x9" Cragar SS 610C wheel. 5.5" backspace, 13mm offset, 115mm bolt pattern should work fine for an R/T?
I want to make sure before I order them.
Thanks
