So I just picked up my 2015 Challenger SXT plus yesterday which has the base 8.4A & sound group 1 package, I have my full setup I used to have in my Magnum that I will be putting into the Challenger, the first step will be adding sub (debating on if I should put both 12" subs, or just one), but my first question before I even start planning things out is where is the best spot to tap into the factory system to hook up the sub amp? Is there a line level output anywhere on the factory harness for the factory sub options, or is the only option to tap into the speaker?
