6.1 or 6.4 cam swap
1 reading
5K views 9 replies 4 participants last post by  Bradley Manning wannabe
Does anyone know of a dealer in Michigan that will do a cam swap in a 5.7
#7 ·
I doubt a dealer would do that...essentially you're going beyond what combination of parts they would install on a 5.7 beyond what their manuals call for.
Then there's the liability on their part if something didn't go right.
The 6.4 cam will work, it requires different valve springs (5.7 and 6.1 springs will coil bind with the higher lift) and the 6.4 springs won't work since the installed height wouldn't be correct.
You can get aftermarket parts (valve springs, retainers, pushrods) that will work for the 6.4 cam swap into the 5.7 (I've done my own after researching the threads here on CT) and to optimize the tuning for the new cam (higher lift, longer duration), you'll need customized tuning to realize the gains the cam will afford.
#8 ·
Actually some dealers will...The two local to me would jump at it in a heartbeat to do something different...I would bet Steve White would do it.........only issue is you better do your homework and know what is needed (springs, etc) because while the dealer techs can change a cam they usually only know standard OEM procedures.
OP you might PM Hemi31. He is a member here and can do the job or know who is local to you..
