How to change dust boots on Brembo calipers without removing them
1 reading
16K views 5 replies 3 participants last post by  Janson
#1 · (Edited)
Over time your Brembo calipers may get cracks in the piston dust boots. When this happens, dust/dirt can get into the caliper pistons and cause them to not engage properly. Sticking caliper pistons can exhibit one or more of the following symptoms:
  • Car pulling to one side
  • Uneven brake pad wear
  • Increased brake pad wear
  • Excessive rotor and caliper heat
  • Reduced braking effectiveness
If you are able to catch and change your dust boots before they crack then you will be able to avoid having to rebuild your calipers. When in doubt, change em out.
This guide will review how to change the dust boots without removing the brake calipers. The guide is specific to the four-piston Brembo calipers that are on the older SRT Challengers and Challenger Scat Packs without the optional six-piston Brembos. However, I can't imagine the process will be much different for the six-piston Brembo calipers.
How to change the caliper dust boots without removing the caliper
  1. Remove your brake pads, unbolt your caliper and use a bungee cord to hang it off of your spring (to prevent it from hanging by the brake line).
  2. Clean the inside of your caliper. I use brake cleaner and blue shop towels. If buildup is really bad, use a small brush.
  3. Pump your brakes in small increments until the pistons start to come out. The pistons may come out unevenly. This is normal and doesn't always mean that you need to rebuild your calipers. You want to target getting all of your pistons to come out but not too far. Please be aware that if you pump the brakes too much that the pistons can come out. If you are nervous about them coming out too far, put a piece of wood inside the caliper to prevent it from happening. However, if you take it slow, they will not come out too far.
  4. Closely examine your caliper boots. Do they show any wear? Are there any small cracks starting to form? This image is from my rear calipers on my 2015 Scat Pack with 45k miles and 8 track events.
  5. 1007120
  6. Use a small flathead screwdriver and press it between the boot and the caliper on each side. The caliper dust boot should pop off fairly easily. The front calipers have a small notch on the dust boot that you can use to place your screwdriver.
  7. 1007121
  8. Once you remove the caliper dust boot, use a clean rag and wipe around the piston. You can also use a large flathead to pry out the piston slightly further and to wipe around the outside of the piston (where the highest chance of dirt buildup is).
  9. 1007122
  10. Slide the new caliper dust boot onto the piston. Twist it in a circle to ensure it is completely locked into the groove and not folded over.
  11. 1007123
  12. Press the piston back down and then press the caliper dust boot into the caliper. Be careful not to tear the boot if you use a tool to press them. The rear calipers I was able to press in by hand. The front calipers I used a piece of wood. You want to ensure that you press the piston down first so that you don't trap a bunch of air between the dust boot and piston.
  13. Repeat for the remaining dust boots. Please note, you should always perform brake work in pairs. Meaning if you have a cracked boot on the left rear, you should go ahead and change out the dust boots on both rear calipers.
***Update 6/1/2021
Important Note: Centric/StopTech dust boots which are advertised as high temperature are not good quality. My original Brembo dust boots lasted over 5 years and 8 weekend track events before they started cracking. I installed the Centric/StopTech boots and they have already started cracking after two events. The one thing I noticed when I first installed the Centric/StopTech boots is that they were extremely thin. I would recommend purchasing authentic Brembo replacements if you perform this procedure.
Caliper Boot Sizes
Standard Four Piston Brembo Calipers
Front - 44mm
Rear - (qty 2) 28mm (qty 2) 32mm
Six Piston Brembo Calipers
Front - 36mm
Rear - (Unsure, if someone can help me here I will update this later)
Piston SizeBrembo Dust Boot Part Number
28mm20.4872.40
32mm20.4872.42
36mm (6 piston models)20.4872.44
Sources
Zeckhausen Racing - While Zechhausen sells extremely overpriced replacement dust boots by Stoptech/Centric, they are not good quality. They are extremely thin and didnt hold up well for me and a few other challenger/charger users in other forums. However, they do sell other replacement parts.
Hoerr Racing Products HRP **RECOMMENDED - I ran across this gem of a company the other day. They sell authentic Brembo dust boots which are far better quality than Stoptech/Centric and at a great value. I placed an order over the weekend for dust boots along with some racing gear and they promptly called me this morning to tell me they were out of one of the other products that I purchased and asked if I would like them to order it with a delay or to remove it from the purchase. I am very impressed with their prices and service.
#5 ·
You have a few options regarding replacement dust boots. Ironically, the pricing makes no sense. However, there are not a lot of companies that make replacement boots.
Front - Zeckhausen Racing, Ohio Performance Solutions, and Summit Racing sell these. They typically come with dust boots and inner piston seals. Some vendors sell the kits for two pistons (you would need two kits per caliper) and some sell them for four pistons. The rebuild kits from these vendors are made by StopTech (owned by Centric). I bought mine from Ohio Performance solutions because their kits were cheaper and contained caliper rebuild fluid (which I used to rebuild the calipers and change the pistons). Ohio Performance Solutions kit ran approximately $40 for each caliper which was approximately $10 cheaper than Zeckhausen Racing. However, they seem to be out of stock as of this morning.
Rear - These come as a rebuild kit that includes dust boots and seals. I found these on Summit Racing for $14 a kit. Each kit included dust boots and seals for one caliper. They are listed as a Centric part, however, they are the same exact quality and material as the Stoptech kits that I purchased for the front (part #143.63034).
Lastly, you can always purchase the dust boots (only) from the dealer. The dealer sells Brembo replacements, however, they are very expensive and I had trouble finding any dealer that had them in stock.
I've got an upcoming track event in a few weeks and will update this post if I find any issues with the Stoptech parts.
#3 ·
I've never seen dust seals crack like that before - have you been giving the brakes a serious heat work out? Or cleaning regularly with something nasty?
They usually tear in the thin moving bit, or just get corrosion under them from inside (water being absorbed in the fluid corroding the pistons.
I've seen them "balloon" - the rubber swealling up from contact with grease or copper-ease smeared too thickly on the back of the pads to try to stop pad squeal.
#4 ·
Track events at Michelin Road Atlanta speedway. That track is very hard on brakes. On the longest straightaway I hit approx 140mph then brake hard in a downhill braking zone. I have no doubts that if I didn't do track events then they wouldn't be this bad at this time.
Thanks, where did you get new boots?
I'll post where I got them later today when I'm at my pc. I'll also list the few options that are available.
Reactions: clazar2121
#6 ·
Updated the post regarding my experience with Centric/StopTech dust boots as well as size reference info and sources.
