So I am looking though my parts list on the cam kit, my next step is gaskets. I am not wanting to cut corners, but if I can get similar quality product cheaper somewhere else that is always nice.
Being said, Brian Tooley Racing quoted me OEM Mopar Performance gaskets for the head gasket, header gasket, valve cover gasket, timing cover gasket, crank seal, and water pump gasket. I have not compared prices, but are these gaskets similar to what you would pick up at your local O'reilly?
For anyone who wants to see the full list...
RIGHT SIDE HEAD GASKET
1 x MOPAR PERFORMANCE 5.7 GEN III HEMI HEAD GASKET - RIGHT SIDE - 53022306AC $71.55
LEFT SIDE HEAD GASKET
1 x MOPAR PERFORMANCE 5.7 GEN III HEMI HEAD GASKET - LEFT SIDE - 53022307AC $71.15
RIGHT SIDE HEADER GASKET
1 x OEM MOPAR - 6.4 EXHAUST GASKET RIGHT - 05038098AA $29.99
LEFT SIDE HEADER GASKET
1 x OEM MOPAR - 6.4 EXHAUST GASKET LEFT - 05038099AA $24.99
HEAD BOLTS / STUDS
2 x OEM MOPAR GEN III HEMI HEAD BOLT KIT - HEMIHBK $109.99
VALVE COVER GASKET
2 x OEM MOPAR - VALVE COVER GASKET - 05114179AB - 2 NEEDED PER ENGINE $79.99
TIMING COVER GASKET
1 x OEM MOPAR - TIMING COVER GASKET - 53021521AD $21.99
FRONT CRANK SEAL
1 x OEM MOPAR - FRONT CRANK SEAL - 53021585AD $21.99
WATER PUMP GASKET
1 x OEM MOPAR - 2009+ 5.7 & 6.4 CAR WATER PUMP GASKET - 68394131AA $29.99
MDS BLOCK OFF PLUGS
4 x OEM MOPAR - MDS BLOCKOFF PLUGS - 53032221AA - SOLD INDIVIDUALLY - (4 NEEDED PER ENGINE) $16.99
CRANK BOLT
1 x OEM MOPAR - CRANK BOLT - 06510763AA $10.99
CAMSHAFT BOLT
1 x OEM MOPAR - VVT CAMSHAFT BOLT - 06102430AA $6.99
HEAD BOLTS / STUDS
VALVE COVER GASKET
TIMING COVER GASKET
FRONT CRANK SEAL
WATER PUMP GASKET
MDS BLOCK OFF PLUGS
CRANK BOLT
CAMSHAFT BOLT
