2021 Scat Pack M6 - Any way to keep Sport Mode as the default setting? I've been having to reset it to Sport Mode every time I start it - thanks!
What do these Tazers cost? Is there a downside voiding warranties or any other disadvantage of using Tazer to disengage ECO mode to automatically start in Performance mode on new Dodge Challenger SPWB?Tazer - Startup Drive Mode: Like driving in Sport or Track mode every time you get in your car? Tazer can set the startup drive mode for you, so you don’t need to switch modes every time you get in the car.
Is there any way you can screw up the car with this? I see lots of other things one can do like open windows using remote. Most important feature I would think would be to be able to start 8 spd. auto Challenger in performance mode or out of that multi-displacement mode so that the engine does not prematurely wear out.Looks like around $300 with the double bypass
Tazer
Description 2018+ Models: Due to the addition of a security module, a Double Bypass or Security Gateway Bypass Module is REQUIRED for the Tazer to function! NEW in firmware 2.5.8 (11/14/22): PIN Lock allows you to set a steering wheel button sequence (PIN) that must be entered before the vehicle...www.zautomotive.com
So whatever you change you can un do it?I have no personal experience, but it doesn't make permanent changes like a Tune can
Wow! The tools of technology have really come a long way.2018 and above vehicles are equipped with a new device called a security gateway module. The purpose of this module is to prevent CAN bus hacking over the 3G or LTE network. It also prevents access from the OBD-II port by anything other than the dealer diagnostic tools. The double bypass gives you a 2nd OBD-II port to connect the Tazer (and other OBD-II devices) to
It would be for a new 392 SPWB 8 spd. auto. once they get this chip problem solved.I've seen quite a few members here that use it. It depends on what trim you have and what new features it offers if it's worth it to you. I rarely see people have issues caused by it posted
I would think it be more for the start car in performance/sport mode rather than that "ECO" MDS mode or cylinder deactivation mode.Scat Pack Widebody it doesn't add much. Unless you want it for one specific function, you won't gain much
No sir not having that issue. Wouldn't know how to fix it. Look at your car manuel.2021 Scat Pack M6 - Any way to keep Sport Mode as the default setting? I've been having to reset it to Sport Mode every time I start it - thanks!
The Tazer will let you keep it in Sport mode i bought one just for that plus you can setup some sweet splash screens.I asked the same thing recently and was told that it can be done. But I haven't tried yet.
I will today and post it if I am successful.
So if you keep car in the default mode which is "Auto" just doing that or switching over to sport or track will eliminate the MDS problem?Default can be auto or eco but it can’t be sport or track.
That's fine as long as the Auto mode doesn't cause same problems the MDS ECO mode does with motor. One can always just leave in "Auto" mode or switch to "Sport" or "Track" mode to keep away from that MDS mode.MDS AND SOFTER TRANS SHIFTS IN AUTO. SPORT AND TRACK STOP MDS
