I am at the alignment shop and they said asked if I wanted to adjust the frame because it was off from factory. Should I do that or is it bad? I don’t know if it was off from factory, he said a lot of Chrysler cars have some off alignments.
I don’t want to void warranty or anything
And he also suggested aftermarket front upper control arms to get it even more aligned
If we shift the frame it won’t bring it to spec but maybe just closer
Please let me know what you suggest thanks!
The writing on the right is the factory numbers that the car is suppose to be at.
Are the after numbers okay?
The alignment guy says in the long run it probably will wear from on the inside, but that's also sporty
From the factory for some reason the left and right aren't the same numbers and that's just a Dodge/Chrysler thing. No one else seems to have different left and right numbers.
He suggested if I want things perfectly straight I would need to get and install this
www.jegs.com
SPC 66047 cam/caster arm
Is it a good idea to get it straight? Straighter than factory? Does adding that void warranty?
I never was in an accident, are my before and after numbers okay?
I hope there was no frame damage from the nightmare bodyshop/Dodge dealership experience I had
SPC 66047: DODGE CAMBER/CASTER ARM EA - JEGS High Performance
Buy SPC 66047 at JEGS: SPC DODGE CAMBER/CASTER ARM EA. Guaranteed lowest price!
