Check engine light code p1217 2015 srt8 challenger
1 reading
25K views 9 replies 6 participants last post by  Scatboy408
I know there is probably already a thread out there in regards to someone throwing this code (P1217). However, those of you who experienced dealing with this issue or know of someone who has, could you please shed some light on how the matter was resolved and how long it took?
Any feedback would be highly appreciated. Last but not least, I hope you guys enjoy your Challengers as much as I do. This is my 6th Mopar.
2015 Sublime Green SRT8 Premium
8 speed trans
24k Tech Group.
#5 ·
There is a TSB for that that requires a Flash # 18-035-15
· Unable to accurately increase or decrease the cruise control set speed using the
resume or set buttons while the instrument cluster is set on metric units. Instead of
changing vehicle speed by 1 KPH when pressing the buttons, the vehicle speed will
increase approximately 1.6 KPH.
· Slight spark knock condition during aggressive high speed driving which may
prevent the vehicle from achieving maximum top speed.
· P1217 - Active Exhaust Valve 1 Performance.
· P121B - Active Exhaust Valve 2 Performance.
#7 ·
Hey guys, so I just traded in my 5.7 for a used 2016 6.4 and 2 weeks in I get this error code. I looked under the car after seeing this thread, I'm assessing I dont have the Exhuast valves and that's why I'm getting the code right.
Yes, exactly. Same thing that would happen if you pulled the fuses to disable the Active Exhaust Valves.
#9 ·
You could install active exhaust valve simulators...basically a mechanism that mimics the operation of the valves. But the big question is...where is the wiring for the valves? Was it just cut off? Tied up somewhere?
