Dodge Challenger Wide Tire Suggestions
2.8K views 8 replies 5 participants last post by  Sat3.6
Hey Guys!!
I have a dodge challenger GT AWD with everything stock for now. And I am planning to buy new tires. Right now it's at 235/55R/19 but I want to buy some wide tires. So, does anyone know how wide I can go on tires with my stock wheels (19”) without damaging fenders, shocks, etc.?
Thank you!!
#3 ·
Welcome to Challengertalk ;) That is a 7.5" wheel, and 235 is already the widest recommended tire size for a 7.5" wheel. You can go wider on wheels and tires, but just not on that stock wheel
Reactions: Jimmy N.
#5 ·
You don't have to get 20", you can still get 19" wheels, but the tire choice is more limited. The thing with AWD wheels is their offset is high between +50 and +55, whereas the RWD wheels are generally between +15 and +25. The correct size and offset wheel/tire combo won't cause any damage. Here is a answer from another thread that might help you as well
There are AWD Challengers that come with 20x8.5" +50 wheels and 255/45ZR20 tires, but they would only be .7 of an inch wider than the 235/55R19. So aftermarket wheels that are 9" or wider and of a proper offset would be the way to go if you want wider than stock
#8 ·
It will just make the wheel/tire stick out more. As I say, members have used OEM RWD wheels and been fine
#9 ·
Hello guys back again!!
just a quick question. I am planning to lower the height of my challenger awd and i am bit confused. So, i will be running stock size for winter tyres (235/55R/19) but for summer tyres i plan to go with (275/40R/20) tyres. So my question to you is:
1. Should i buy lowering springs or coilovers for my car? Because i have to change the height of my car everytime i switch the tyres.
2. How much will they drop my car? (Both springs and coilovers).
Thanks
