Thanks, I will look into it. At the least I hope to learn how to do more than a basic wash and how to wax
You’re asking for very different things. Washing and waxing are different from paint correction. You noted you have scratches, only way to remove said scratches is paint correction which why I think you’re better off leaving that to the professionals.
That said, to avoid scratches and best care for the car use proper washing techniques ideally bi-weekly but let’s be honest, who really has that kind of time? I do mine and my clients monthly. Most the time I don’t get to my car until month two or three, however mine is ceramic coated and I spot clean which most people don’t do. Bird droppings and bugs I remove immediately and if my car gets hit with sprinklers or something I wash it ASAP. Water spots will kill any protection and etch into the paint if not removed which can be a costly fix.
The basics of detailing will be most beneficial to you. Two bucket method works great, I prefer the multi mitt method where I use like 6 mitts on my car so I’m never introducing dirt to my bucket. I use a separate bucket and mitt for wheels/tire area.
Shampoo, I prefer something that has great lubricity and rinses clean.
My personal faves:
• Meguiar’s Gold Class
• Turtle Wax Slick n Slide
• Adams Shampoo
• 3D Pink
Mitts I prefer ones that don’t have pockets. For drying CarPro makes a solid towel as does Autofiber.
I highly recommend you get a rinseless wash, whether it’s ONR, Absolute, DIY Detail whatever, I use rinseless more than anything. Great as a drying aid, maintenance for interior and exterior, glass cleaner, spot cleaner for bird poop and bugs etc. Also get a rinseless sponge if you plan to use it for maintenance washing. Microfiber works ok, but you need to use a specific technique called the roll technique, otherwise you’ll scratch the paint all to hell. Sponge however, easy peasy, glide it on, then dry. Simple.
For protection I prefer sealants over wax. Collinite is solid but does take a minute to anpply. It says it’s a wax but has a synthetic base with some natural wax infused which is why it lasts so long. If you use just straight up carnauba wax, it’ll be gone within a month.
If you go the Collinite route it’s best to apply over the whole car, let it sit for 30 minutes then wipe off. Just be sure to avoid plastic trim or matte finishes, which is why I prefer sealants as they typically work fine one these surfaces or at least no adverse reaction.
Sealants I like:
• IGL Premier (6 month but easily give you a year of protection)
• Shine Supply Clutch (works great on plastic trim too)
• System X Renew (longevity isn’t quite 9 months as they claim but slick as hell)
• Meguiar’s M27 (works similar to Collinite but won’t harm trim)
Toppers (used after a wash to give a boost of gloss and slickness)
• Aqua Tek Synth
• P&S Bead Maker
• 3D Bead It Up
