2021 Scat Pack M6 - Any way to keep Sport Mode as the default setting? I've been having to reset it to Sport Mode every time I start it - thanks!
I'll have to look into that. My understanding is that the valves were all the way open for sport as well but I could be wrong.Wasn't aware of the older "Sport" button. Yes, with drive modes you can push the button and then select the mode you want. But, as stated, easiest way is to set your favorite mode to the "Custom" mode. then when you start up, just hit the Drive Modes button twice and it goes straight to custom mode. No screen touching required.
My impression is that the valves are partially open in Sport, fully open in Track. I just installed this and now they are open all the way, all the time. Regardless of mode.
Inactive Exhaust / Active Exhaust delete for Chargers, Challengers and 300’s from 2015 to present
Inactive Exhaust / Active Exhaust delete for Chargers, Challengers and 300’s from 2015 to present (Z_AES_DELETE)zicmoto.com
Yes, I may be confusing traction control for exhaust valves. I need to look again.I'll have to look into that. My understanding is that the valves were all the way open for sport as well but I could be wrong.
Unfortunately with the newer setup you don't have a button anymore. With my new TA I have to navigate through the touch screen to get to the performance settings just to activate "Sport" or "track" etc.. My old '18 SP just had a button on the console. It's a little bit of a pain that way.
That's a fantastic reference video! I've watched his video on his shaker install and he makes good videos. Well, track mode it is!I believe only Track or Drag modes has them full open naturally. I think Sport mode is only like 70% open? The Tazer can keep them open all the time as will the Inactive Exhaust obviously
Re labeled button to "Drive Modes"?Wasn't aware of the older "Sport" button. Yes, with drive modes you can push the button and then select the mode you want. But, as stated, easiest way is to set your favorite mode to the "Custom" mode. then when you start up, just hit the Drive Modes button twice and it goes straight to custom mode. No screen touching required.
Why does yours have a "Sport" buttom vs. a "Drive Mode"?I think he means he had this
That’s not mine. I was showing/clarifying what poster #73 was referring to in his 2018. My ‘21 has the drive mode button.Why does yours have a "Sport" buttom vs. a "Drive Mode"?![]()
And to further muddy the waters, my SRT 392 has an SRT button! 😬2015 thru 2018 has the Sport button (Dodge Performance Pages)
2019 and newer has Drive Modes (SRT Performance Pages)
Too many buttons to push. Just hop in and drive.After playing with the custom settings for my new TA 392, it seems that the exhaust valves may be tied to the traction setting. When I tried a custom setting with traction in sport and steering in track, the exhaust was softer than my "track" mode setting. I could be imagining it but I thought I could tell a difference.
I am trying to learn the same thing. I started thinking ot was tied into the transmission setting. It was a short trip. But that's what my ears told me. I guess I can try the traction.After playing with the custom settings for my new TA 392, it seems that the exhaust valves may be tied to the traction setting. When I tried a custom setting with traction in sport and steering in track, the exhaust was softer than my "track" mode setting. I could be imagining it but I thought I could tell a difference.
So the double press brings you to last used mode or just your custom settings?Yes, double pressing the Drive Mode button is the same thing as going through the screens in order to select your Custom Drive Mode. And as someone previously said, it's the first thing I do when I start the vehicle.
Your Custom mode.So the double press brings you to last used mode or just your custom settings?
Roughly $250 for the double bypass version and what ever settings you apply initially will stay that way every time you start your car.What do these Tazers cost? Is there a downside voiding warranties or any other disadvantage of using Tazer to disengage ECO mode to automatically start in Performance mode on new Dodge Challenger SPWB?
I doubt it. I run Sport mode usually and go into eco for a bit here & there on any longish highway runs which for me is few & far between.Has the data ever been presented to show the lifter failure is caused by not being in sport mode?
Doesn't running in "ECO" mode shorten the life of the engine and you notice a big difference in how the car runs when you switch to "ECO" mode?I doubt it. I run Sport mode usually and go into eco for a bit here & there on any longish highway runs which for me is few & far between.
install a non MDS cam, and tune it then set the default settings in the tune to shift the trans like it is in sport mode and set up driver demand mode for normal mode to use Sport mode with HP Tuners.Has the data ever been presented to show the lifter failure is caused by not being in sport mode?
