Why did it take almost 5.5 hrs to hand wax car?
5.6K views 27 replies 22 participants last post by  jonmandude
Hello, I have a 2011 Dodge Challenger. I decided today to wash the car with a machine at the car wash, dry it with cloth, apply a paste wax by hand, wait for it to dry, remove the haze, and then clean the wheels:
-took me almost 5.5 hrs. is this normal? I remember paying a cra wash 30 bucks to do the car wash and wax with one of those buffing machines and I was out in 45 minutes.
-also do you think I did it wrong: It took me a REALLY long time to get the hazy wax once it dried completely off: I mean my finer tips were killing me....
#4 ·
That's why I've only waxed my truck twice in 10 years. The first was after its first wash and the second was when I washed it for the first time in about 6 years and realized it was heavily oxidized.
I hand applied a clear coat safe rubbing compound then hand waxed it and used a buffing machine and some polish to shine it up. The whole process took maybe 3 hours.
With the challenger, I just use a synthetic polish/wax like Turtle Wax ICE. I last applied it almost 8 months ago. I got caught in a rain storm and was surprised to see the water beading up and running off still.
Did you wax it in the shade? If you wax in the sun, it dries fast and is hard to get off.
#5 ·
It takes a long time if your really anal about doing it right.
As to trouble getting it off...
That could be the wax brand itself, as some brands are just a real bugger to get off.
Or as mentioned above doing it in the sun or on a hot car.
#6 ·
I like to put it on in very thin coats. Wax that doesn't touch the paint doesn't do you any good.
I use liquid wax and don't let it dry for very long. It's easier to remove and makes little difference as far as I can tell.
My tips:
- Change rags often. A waxy towel gets hard to use and ineffective. If you feel the rag is hard to rub turn it over or replace it.
- Wax in straight lines not circles. If you accidentally scratch the paint a straight scratch is harder to see than a swirl.
- Cover non painted items with a clean towel so you don't get wax on them.
- Use liquid wax not paste. Paste waxes can become hard and scratch.
- Use good wax like Meguires. Old fashioned Turtle Wax is no good. I've heard ICE is good though.
- Cleaner, rubbing compound, and polish are used to resolve (or create) problems with your paint. If you don't have problems don't use them they are abrasive.
- Waxy cars are much easier to wash. If you're car isn't waxed dust and pollen don't come off easily. You can tell if you dry the car with a white towel and the towel gets dirty.
- Waxing wheels is good, windows is not. Wax works on glass, but when the wax breaks down over time it makes the glass hazy until it's applied again. Same issue with Rain-x. Waxing wheels makes cleaning easier as dust doesn't stick as well.
- If you don't know how to use a machine don't use one. They can do a lot of damage.
#21 ·
Folks referring to these cars as massive just cracks me up!!! You'd have a complete meltdown if you had to wax/polish my Ram 2500 Mega Cab....or my wifes' Suburban.....these are mid sized cars and hardly qualify as massive!!!!:pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle::pillepalle:
#8 ·
wash, clay bar, wax, and buff will take some time. Meguires NXT 2.0 comes off really easy
#10 ·
Washing is a good solid 1 1/2 hours for me. The wheels alone due to the brembo brake dust is ungodly and like nothing I've seen before. Rest of car, while big, isn't that bad. But like most of you guys, I'm anal and use multiple buckets and mitts, always wash everything carefully and carefully dry to avoid scratches.
As for waxing, don't use a wax, get a good paint sealant instead. Lots out there. Provide better/longer protection and easy on/easy off. I use Wolf Gang and Rejex, but Turtle Wax, Meguiars, and others all have their own sealants now. Zaino is also a big one, but its like joining a cult - those guys are nuts!
I can apply a sealant in 1/2 hour, let it sit for an hour or more, then remove in another 1/2 hour. All by hand. Bit of work as the doors and hood are massive, but comes off easy enough.
#14 ·
I am guilty as a cult member. My friends all think I have lost my mind, lol. Its a labor of love, and once you try it you will never turn back, guaranteed.
#12 ·
Responses
Guys thanks for the responses, so many great answers:
-I used soem old school Turtle Wax the past chip dip kind of wax
-I think I used too much wax. When the wax dries should the color be really white and hard to get out
-I ahd to rub it out with a microfiber really hard.
I used to sue the Ice Wax some were taking about, but IM not sure if it is lke a conventional wax.
#18 ·
Some quick, random thoughts....
I agree with others that suggested you may be using too much. I also agree with the one member who said some products can be a real PITA when applied to thick. ....Finish Kare 1000P comes to mind.
Obviously, you should follow the manufacturer's directions but for traditional (apply, let dry and remove) products, you can typically do a "finger swipe test" if you are unsure if the product is ready to remove. Basically, use your finger and swipe across a section where the wax has hazed. If the paint underneath looks clear (with no smearing), it should be ready for removal.
A tip in the future is trying a quick detailer (QD) to aid in the removal of excess product. Test in a small area first to check compatibility/results before continuing on with the rest of the vehicle.
Something else to consider (which was also mentioned) is possibly switching to a more user-friendly product. There are a myriad of waxes, sealants and coatings available these days to choose from rather than putting up with something that is proving to be a bit finicky for you.
#15 ·
yall must suck at waxing
I get it done using meguires gold and microfiber towers in about 45-55 minutes
however I keep my car spotless so its really easy to wax
instead of washing I dont drive it enough I use turtle wax bug/tar remover
might I suggest you switch to turtle wax ice
wax any car in about 15 minutes( I use it at car shows)
#16 ·
You must have small hands... ;)
Waxing and wiping Tech Wax takes me about 1.5 hours... (and that includes masking the stripes)...
#19 ·
No problemo mi hombre! Gave Baby her inaugural hand wax job using a no frills McGuire's carnuba paste and I said "Job well done!" after exactly 6 solid hours. Mine polished up very well using a soft bath towel and then a micro fiber - flipping, wiping, flipping and wiping. I used the bath towel as the haze remover and then the micro fiber as a polisher. Perfecto!
#23 ·
I have never used a sealant. You say mequiers has one? I have not seen it before. What's it called?
I use nxt 2.0 on the entire car. It usually takes me all morning and then some to fully wash and wax. I use mothers wax attack orbital. But I'm particular. My rims take the longest because I want insides to shine as much as possible. I take them off and do a full cleaning at least once a month and wash inside by hand every wash.
Sent from my Autoguide iPhone app
#24 ·
....if you have used NXT, you have essentially used a "sealant".
My advice? ....don't get hung up on classifications. There is no industry standard when it comes to terminology and detailing products. In this case, Meguiars chose to use the term "Wax" in the name of NXT Tech Wax because it is product marketed for the average consumer/DIY'er. The fact is, it is a blend of polymers and other synthetic components. Another example is Zaino Z-2 and Z-5. Both are labeled as a "polish" yet they have no abrasive characteristics and in fact are both sealants (Z-5 does have some filling ability however). I'm still not exactly sure what Sal's thinking was on that one.
Generally speaking, "sealants" are usually thought of as synthetic formulations and "waxes" as products derived mostly from natural wax components (i.e. carnauba). There are also blends, hybrids, cleaner waxes, AIO's (all in one's), etc.
Personally, I prefer to judge products based on their own characteristics and performance. There are so many with varying traits, formulations, blends, etc. that it's not always easy to clump them all into neat categories. There is nothing wrong with using a "wax" or any other type of LSP (last step product) if it meets your criteria and works well in your scenario.
As for Zaino's zealot-like following (or even companies like Adams, Griots or even Meguiars), you need to understand that many of their customers are typically average consumers usually in a state of transition from the limited experience of OTC/retail products they have used and have little knowledge of detailing (but are usually eager to learn more at this point). When they eventually try these products/systems, they can make quite impression and some will even believe there is nothing else on the market that is better.
....now, having said that, I will first say that I have been a long time user of Zaino products. ....and they are good products. However, there are a lot of other "good" products out there as well. I don't use Zaino exclusively or any product line for that matter. There are so many with varying characteristics, technologies, etc. for me to believe there is any one that is "best" for everyone. ....best for someone is another story.
What really matters in the end is that you find products, tools and techniques that work for you.
