21 - 40 of 110 Posts
Reactions: clazar2121
Is there a build sheet under the back seat like the old days
No but usually unless the dealer threw them out, there will be a few sheets for the different parts of the car scattered around in the car and trunk. But no, there is not one 'build sheet' like before.
You can enter your VIN# in these links to get a pdf copy of your Window Sticker and/or Build Sheet. Be aware Window Stickers are generally only available for a couple of years. If no longer available you will get an error message "Sorry, There is no window sticker available for this vin" . Make sure VIN# is all CAPS
Window Sticker and Build Sheet
Add your VIN# to the end of these links, all CAPS
Window Sticker
For Canada, some say this works when others do not
https://www.dodge.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
https://www.chrysler.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
Use your VIN number to get Dodge Window Sticker
(Scroll down a bit to box to enter VIN#, then scroll to bottom of results page, hover over Window Sticker to reveal Download or Print options upper right)
Build Sheet
Thanks for the info. That's really neat. My car is built and on its way to the dealership, so I didn't think it would be in the system yet. But it is. Thanks for sharing.
Discussion starter · #33 ·
Welcome to Challengertalk ;)
Reactions: Robs16Hellcat
Does anyone know where to get a duplicate copy of the "ORIGINAL" window sticker that has had a "special build" that has their name on it from? FYI.... for those of you waiting on your special order vehicle you might want to advise the dealership prep team to leave it alone on the window so they don't take it down and fold it up and cram it in the glove box!!! :(
Call your original selling dealer and they can order one for you. Might take a bit to find someone who knows how to do it but it can be done.
So me and my buddy tried both the build and window look up for his charger SPWB that should be in this next week or following both the buildsheet and window sticker are not pulling up “vin not provided” on build sheet and “sorry a window sticker is not available for this vin” on the other I made sure all letters are caps and the vin decodes as the correct vehicle. Any advice ?
